Removing passenger pillion on Deluxe, fender protection
Old Aug 18, 2009 | 08:20 AM
TAZ1238's Avatar
TAZ1238
Default Removing passenger pillion on Deluxe, fender protection
I want to remove the passenger pillion and rack and run with just a fender bib. I know how to remove the plastic protection on the fender. My question is:
If I want the option of having the pillion and rack back on occasionally, is there anything I can put on or lay over the fender to keep it from scratching the paint?
Old Aug 18, 2009 | 08:58 AM
HOGBOY57's Avatar
HOGBOY57
Put the plastic protection piece back on. Just make sure its clean. My wife had an 07 deluxe and she ran with the solo but when we would put rear seat back on i would use the plastic piece.
Old Aug 18, 2009 | 09:00 AM
128auto's Avatar
128auto
I heard ppl putting the pillion on top of the fender bib, you may want to put a towel in between when you ride 2-up.
pwalsh1019's Avatar
pwalsh1019
If the plastic is like what i have there is no way you can reuse that... you can cover the bottom of the seat in som cloth ...
Old Aug 18, 2009 | 11:16 AM
TAZ1238's Avatar
TAZ1238
Thanks guys. I'd have a stroke if I scratched the fender. Maybe I could have a leather cover made for this. Kinda like a wider bib.
Old Aug 18, 2009 | 01:47 PM
chordstrummer's Avatar
chordstrummer
I bought a roll of clear vinyl tape just for this purpose. I think it's 2" or so wide, and I cut strips of it and lay it on the fender. Very low-tack adhesive, so it's easy to remove, too.
Old Aug 18, 2009 | 03:22 PM
jimmers1817's Avatar
jimmers1817
My Mustang bib almost covers all of the plastic protector. Less than 3/16 sticks out on one side and unless you get down at eyeball level you can't even see it. Actually if the thing was centered on the fender the bib would cover it all.
One member here, I believe it was Keno, said he leaves his bib on when he puts the pillion on. Leaves a couple of temporary dimples but otherwise works fine.
Old Aug 18, 2009 | 06:17 PM
qwispichkn's Avatar
qwispichkn
3M makes a thick plastic with a sticky side that you can use. just buy a roll from ebay and keep it for when you want to put it back on.
BLKnCHRME09Deluxe's Avatar
BLKnCHRME09Deluxe
I took off the clear protected tape from my fender and then just used a mustang bib($32.00 e-bay) under the pillion. I have NO/NONE scratching on fender. It works very well. The pillion does leave little dimples on top of bib, but they do disapear after a couple of hours. Good Luck...
Old Aug 19, 2009 | 04:51 AM
hpfatboy's Avatar
hpfatboy
I use a piece of leather as a barrier when i put pillion back on bike. ( SOFT SIDE DOWN ) Works fine, no issues.
