lowering bolts on a deuce
Old Aug 23, 2009 | 01:34 PM
thaasjr's Avatar
thaasjr
Default lowering bolts on a deuce
Hi,
I am looking to lower the rear of my deuce. I don't want to pay the big money for the progressive shocks, etc. so have been looking into lowering bolts. Which kit is the best to go with. I would like to put a kit in that allows me to adjust it back up to stock height quickly for two up riding, etc. I think I read that the arlen ness kit does this. When you adjust them back to stock height do you get your stock ride back. I want to be able to lower it for solo riding and riding around town but raise it back up when the wife and I take long trips together with our travel bags, etc. Will the deuce backrest still work with the bike lowered. Will you bottom out on the bolts.
thanks
Old Aug 23, 2009 | 03:35 PM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
Lowering bolts is lowering bolts. I have the Ness ones...They are no different from brand X cept' some come with new rubber bushings.
Easy to crank the *** back up when needed easy to drop back down. The initial install is the hardest part. Once they are on you are golden.
What would your backrest have to do with anything?
Old Aug 23, 2009 | 04:14 PM
thaasjr's Avatar
thaasjr
the deuce backrest mounts through the fender with 3 studs and nuts on the bottom. I didn't know if you would rub on the bolts if you lowered it. I imagine the suspension doesn't allow you to drop down that far. How hard are they to install. Any special tools, etc. I realize the ride will be rougher with it dropped but if you raise it back up will the ride be good again. Do you have to take the bolts out to raise it back up. I want to be able to quickly raise it back up to standard height and ride at times. Thats why Im trying to figure out which kit is best for this. Thanks
Old Aug 23, 2009 | 05:03 PM
mike06train's Avatar
mike06train
The bolts are adjustable. Make them longer to lower it, shorter to raise it. You can crank them to go back to stock height & ride quality.
Old Aug 23, 2009 | 05:16 PM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
thaasjr;5476511]the deuce backrest mounts through the fender with 3 studs and nuts on the bottom. I didn't know if you would rub on the bolts if you lowered it.
Only one way to find out!! If it rubs toss the backrest man...
Got a floor jack? You got a floor jack you can get the job done.
Dont need to remove em' . Put bike back on yer' jack and readjust.
If you really want it to happen quickly drop $1500.00 on an Airride system.
If you dont need it to happen as quick and dont mind getting your hands dirty buy a set of Progressive adjustable shocks or any of the El Cheapo bolt kits. The bolts kits are in essence all the same some are chrome, some are black, some have extra bushings etc..etc...
Old Aug 23, 2009 | 05:21 PM
Screamin00's Avatar
Screamin00
I have a set of stock rear shocks off my bike with lowering bolts installed already that i would be willing to sell shoot me a PM if your interested
Old Aug 23, 2009 | 05:25 PM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
This is a good route OP....Jump on this dudes offer.
JAE88
Apr 17, 2012 10:37 AM
DMC1
Jul 22, 2011 11:04 PM
Matheny27
Jul 7, 2011 03:37 AM
Deuce 06
Mar 18, 2008 08:16 AM
Deuce Bigelow
Nov 19, 2006 12:25 AM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
