rear lower than front,bad handling?
Old Aug 29, 2009 | 09:04 AM
phatsanders's Avatar
phatsanders
5th Gear
Default rear lower than front,bad handling?
if you lower rear of bike 2",and not front will it change handling of bike? 99 fatboy with 18"s front and rear
Old Aug 29, 2009 | 09:47 AM
handyhoward's Avatar
handyhoward
It will change it some but not to the point of a safety issue... could give you the feeling of riding uphill when you take off.......................
Old Aug 29, 2009 | 01:20 PM
DMJFatboy's Avatar
DMJFatboy
I am running 18's and dropped about 2" in the rear only. It sits low but never really noticed any change in handling.
Attached Thumbnails rear lower than front,bad handling?-010.jpg   rear lower than front,bad handling?-009.jpg
Old Aug 29, 2009 | 04:53 PM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
When the back of my Train was dropped 2" it had some high speed understeer going into tight corners and felt kinda out of sorts. Rode fine but here with our twisty mountains roads in Colorado a guy need to be spot on.
Dropped the front 2" and it turned way better and held its line in said turn better.
Dropped it even more with a set of shorty fork tubes and now it can be hammered through the twisties like a.....Dyna!!
If you are passionate about riding your bike hard? Get the rake angles back where they should be which means drop the front when you drop the rear.... If you just cruise and dont really ride the bike close to the limit? It dosent matter as much.
Old Aug 30, 2009 | 07:15 AM
tk353's Avatar
tk353
i raised the front about 1 inch by getting a larger front tire. then i dropped it 2 inch by getting a smaller tire. the smaller front tire makes turns feel much better like having power steering
Old Aug 30, 2009 | 08:02 AM
aviscomi's Avatar
aviscomi
I'm running with the same set-up as the above quote and I haven't had an issue yet. I tend to ride very fast; but I do throttle down in the turns.
Old Aug 30, 2009 | 08:15 AM
'05Train's Avatar
'05Train
In a perfect world, they should be even and your bike should sit level. My front end sits a little higher than the rear, but it's not worth the effort for me to lower the front. I've got no clearance issues as it is and would like to keep it that way.
Old Aug 30, 2009 | 09:53 AM
128auto's Avatar
128auto
Most ppl don't realize the handling changes until they ride serious twisty road, do front and the back, you will be impressed. I have seen ppl riding with the rear 2" drop without any problem, they learned and got used to you know.
Old Aug 31, 2009 | 09:35 PM
mjp750's Avatar
mjp750
my '04 train has a 2" drop in the azz end only. low speed it will get floppy on you if you don't know it's coming (trains do some of that anyway). but I love the look and don't plan on punishing the twisties as much as enjoying them (or I'd have sporty or a Buell), so I'm not worried about the understeer too much. and I love the even more raked look of the bike and super low slung seat position... but that's on a Train.
on a Fatty, I'm not sure what you'd get from dropping the back and not the front. I was about 48 hours away from getting a Fatty instead of the train, so I love the way they look sitting level. if you do it, I'd like to see some pic's. I'm having a hard time seeing that in my little brain.
Old Aug 31, 2009 | 10:12 PM
phatsanders
5th Gear
yea, im doin front and back,just wondering.....heh heh heh
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
