Handle bar shake
Old Sep 13, 2009 | 07:47 PM
Big Blue72's Avatar
Big Blue72
6th Gear
Cool Handle bar shake
I have a 2004 heritage. The handle bars shake from left to right when I let go of the grips. It seems to only happen when the engine is not in a pull. I've checked the tire, the forks for any play, wheel is straight, and it doesn't feel like there is any play as far as the head bearing goes. It's going to the shop on Thursday, just thought I would see if anyone has had the same problem?
Old Sep 13, 2009 | 08:00 PM
ST Deuce's Avatar
ST Deuce
yes i have the same problem with my 06 deuce. i have no shake, vibration or anything out of the norm until i let go of the grips on a decel. most guys will say dont let go of the grips, LOL! the dealer rode it this spring and said everything is fine. rim looks good, not bent or out of balance. thinking of taking it to a different dealer when i get it winterized this fall. it bothers me but i have learned to live with it. any help would be great.
Old Sep 13, 2009 | 08:25 PM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
Couple issue going from easy to easy...
Check your PSI in both tires front and rear, Balance BOTH wheels front and rear...
Now whip out the trusty service manual and adjust yer' fall away.
Thats the amount of tension on the headstay bearings.
Do those 3 things properly and your Harley will ride arrow straight and not shake unless you have a bad tire....That would be the last resort. A bad tire can make for a long day. And like milk at the corner store.....they have a shelf life.
Old Sep 13, 2009 | 08:28 PM
jcap20's Avatar
jcap20
Default 2007 Heritage
Mine does the same thing at about 30mph. I've tried everything I can think of , but have not been able to stop it.
Old Sep 13, 2009 | 08:41 PM
harleyheaven's Avatar
harleyheaven
Had that problem on my bike and it turned out to be a bad front tire... Good Luck!
Old Sep 13, 2009 | 09:09 PM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
That bad front tire is the worst case scenario is its the most expensive of the shake inducing items!!
Old Sep 13, 2009 | 09:13 PM
SEDELUXE's Avatar
SEDELUXE
Chaz mine happens about 115-120 mph what do u think the problem is????
Old Sep 13, 2009 | 10:16 PM
ChromeJunkie's Avatar
ChromeJunkie
I had that issue for about 3 years. I had taken it to the dealer and they checked everything and said it was ok. I took it to a different dealer since I haven't had the steering head bearings checked in a couple of years and since they adjusted it, problem is now gone.
Old Sep 14, 2009 | 05:56 AM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
The throttle turns both ways Dee-Luxe ya' ham fisted throttle Jockey!!
For the record mine feels like it about to leave the ground and take flight at 110.....
Thats no joke. I hafta let off the gas for fear I will literally leave the road and....Fly!!
Old Sep 14, 2009 | 06:33 AM
WoodsHog's Avatar
WoodsHog
Had the same problem with my Fatty.Adjusted the steering head bearings it it fixed it.
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
