10K service
Old Sep 15, 2009 | 08:30 AM
quackerwhacker09's Avatar
quackerwhacker09
Default 10K service
new to harleys had street bikes before shoulda switched sooner lol any how what does the dealer do at a 10K service?? thanks
Old Sep 15, 2009 | 08:33 AM
kkinderen's Avatar
kkinderen
Grab the service manual for your particular bike. It shows the full maintenance schedule as well as all the procedures. I could list out what is done on a 2003 Carb'd Softail if that would be helpful.
Old Sep 15, 2009 | 09:39 AM
jknowlton's Avatar
jknowlton
at 10,000 Miles Services Needed
ITEM SERVICED PROCEDURE NOTES
Engine oil and filter Replace
Oil lines and brake system Inspect for leaks 1
Air cleaner Inspect, service as required
Tires Check pressure, inspect tread
Primary chaincase lubricant Replace
Clutch Check adjustment 1
Rear belt and sprockets Inspect, adjust belt 1
Throttle, brake, and clutch controls Check, adjust and lubricate 1
Jiffy stand Inspect and lubricate 1
Fuel lines and fittings Inspect for leaks 1
Brake fluid Check levels and condition 3
Brake pads and discs Inspect for wear
Spark plugs Inspect
Electrical equipment and switches Check operation
Engine idle speed Check adjustment 1
Front fork oil Replace every 50,000 miles (80,000 kilometers) 1
Steering head bearings Adjust 1
Steering head bearings Lubricate 2
Steering head bearings Adjust and lubricate every 2500 miles (4000 kilometers) 1,5
Windshield bushings Inspect 1
Springer rocker bearings Adjust 1,4
Fuel door, Tour-Pak, saddlebags Lubricate hinges and latches
Critical fasteners Check tightness 1
Road test Verify component and system functions
NOTES
1. Should be performed by an authorized Harley-Davidson dealer, unless you have the proper tools, service data and are mechanically qualified
2. Disassemble, lubricate and inspect every 30,000 miles (48,000 kilometers)
3. Change D.O.T. 4 fluid and flush brake system every two years
4. Adjust at 500 miles (800 kilometers)
5. Disassemble, lubricate and inspect every 20,000 miles (32,000 kilometers).
Old Sep 15, 2009 | 09:40 AM
jimmers1817's Avatar
jimmers1817
Nothing you can't do yourself with a manual and some basic tools. Hardest thing for me was the steering head adjustment. With all the cables attached I couldn't get an accurate read on the fall away test. Ended up having it done by the dealer @ $42 where I'm sure they just did it by torque or feel.
Old Sep 15, 2009 | 09:43 AM
jknowlton's Avatar
jknowlton
Highly recommend the HD Service Manual for your model/year. Best investment tool. This was posted online.
https://www.hdforums.com/forum/softa...sted-here.html
Old Sep 15, 2009 | 12:34 PM
quackerwhacker09
thanks for the info, didnt figure there would be anything drastic done, just change the fluids , adjust the clutch and give it a good onceover thanks
arrowslinger1980
Jul 9, 2014 03:31 PM
jasonyankees
Aug 31, 2008 09:46 AM
steel_tiger1
Aug 14, 2008 12:50 PM
phog light
Jun 8, 2008 07:17 PM
hockey8787
Apr 29, 2008 09:03 PM
