I need help diagnosing the problem with my bike
Revtech Trans = Absolute Junk.
Nothing personal against you but your tranny is garbage. Revtech motors are also garbage.
You may be having severe internal issues. Adjust the clutch and change the oil but IMO if it even acts up a little after that? I wouldnt ride it and I'm an Idiot!!
They are so bad in fact that the NHSTA has issued recalls on the pre 2001 Revtechs.
SAFETY RECALL NOTICE
REVTECHŽ 6-SPEED TRANSMISSIONS & REVTECHŽ 6-SPEED GEARSETS
RevTechŽ 6-speed motorcycle transmission assemblies and 6-speed motorcycle gearsets sold prior to September 12, 2001 have been recalled because the 4-6 shift clutch can crack or break during use. This condition could cause severe transmission damage. Such damage may occur without warning and can cause vehicle control problems,including locking of the rear wheel.
Owners of motorcycles with RevTechŽ 6-speed motorcycle transmission assemblies and 6-speed motorcycle gearsets should bring the equipment to a RevTechŽ dealer to have the recall service performed without charge.
Owners can call the RevTechŽ recall line for information regarding the recall and RevTechŽ dealer locations: 1-800-815-9762 or 1-408-778-5943
Can do everything for under $100....all 3 fluids.
http://www.redlineoil.com/Products.aspx?pcid=19
Get some new o-rings for tranny/oil drain plug, HD part 11105 or #41 o ring from Home Depot in plumbing section.
