vibe when starting out?
Old May 12, 2008 | 08:56 AM
Leester's Avatar
Leester
Default vibe when starting out?
Hey everyone just wanted to ask, when i start under way from a stop 1st gear is really vibratety and jerky if thats a word, if i start out alittle harder accelerating the vibe is more normal at the pegs, could this be a loose primary chain,clutch adjustmentor just normal? Like i said earlier im new to harleys just trying to get a feel for my nightster, i only have 230 miles on maybe it will get better, wont it?
Old May 12, 2008 | 09:08 AM
DPete's Avatar
DPete
Default RE: vibe when starting out?
I'm sure your fine the tall 1st gear takes some getting used to. Give ita little more gas
Old May 12, 2008 | 09:14 AM
cHarley's Avatar
cHarley
ORIGINAL: DPete
+1 Get the RPM's up and slowly slip out the clutch.
Old May 12, 2008 | 09:23 AM
hogsport's Avatar
hogsport
like Dpete said, when starting out and whenever under 12 mph, increase your revs to about double idle (1800 rpm), use the friction zone of your clutch, like you are riding the clutch - it is a wet clutch you cannot hurt it. Don't fully engage your clutch until you are over 12 mph. You will get the hang of it.
Old May 12, 2008 | 09:25 AM
3power's Avatar
3power
+1 to all above - work the friction zone until your revs are up.
Old May 12, 2008 | 09:42 AM
Leester's Avatar
Leester
Thanks thats what i was thinking, just wanted to hear it from other people, this bike is cool as hell!
Old May 12, 2008 | 10:09 PM
jackofhearts's Avatar
jackofhearts
Indeed some of that is normal, but if you are approaching that 5000 mile mark, the primary chain could be getting loose. I adjusted mine (easy to do) at about 4000 miles and I thought had a dream, it was a big improvement. would'nt hurt to check it, especially if you can handle a wrench.
JONNIEROCK
Oct 14, 2024 06:40 AM
NCBANDIT
Mar 11, 2019 04:52 PM
Myke Malicious
Oct 18, 2015 10:52 PM
hitman1267
Jan 22, 2015 08:12 AM
99octane
Jan 24, 2008 08:03 AM
