broken pipe on fxstc
Old Oct 6, 2009 | 07:19 AM
Big P's Avatar
Big P
Default broken pipe on fxstc
Ive got long drag pipes on my 90 softtail and the bottom pipe is cracking by the forward hanger is this common? My bike has motor work and vibrates quite a bit should I go for shorter pipes or do you think this is a freak thing.The pipes were on bike when I bought it so I dont even know the brand.I like the look of the long pipes but dont want to spend the cabbage on a new set and have the same problem. Just looking for some input.Thanxs.the bike was tipped on that side in a trailer once but I wouldnt think that would weaken the steel pipes!
Old Oct 6, 2009 | 07:46 AM
Wallaby's Avatar
Wallaby
How many miles on the bike, could just be a poor weld from the factory or just a stress fracture from the vibrations over time. Can you just weld up the crack on the mount until you can raise the $$$ for a new set. Maybe search Ebay for a 'gently' used set of pipes.
Old Oct 8, 2009 | 07:39 AM
Big P's Avatar
Big P
only got 13000 miles on it could be defect already workin on funds to replace after this season got some models scoped out think im goin shorter might help
Old Oct 8, 2009 | 08:24 AM
Theo's Avatar
Theo
Do the pipes have heatshields? I ask because if not, you can take it to a place and have them weld the crack. It shouldn't cost more than 40 bucks. I guess you could still take it if it does but then it will be visible.
Old Oct 8, 2009 | 11:56 AM
Theo's Avatar
Theo
I was just at the auto supply store and I saw that they have high temp metal fillers and crack sealants. So you could go that route as well.
Old Oct 9, 2009 | 06:17 AM
Big P's Avatar
Big P
no heat shields straight pipes the cracks are pretty bad and causing vibrations I dont think a filler will hold up at this point thanks for ideas I think its gonna be a good excuse for new pipes with heat shields so I wont have the bluing maybe I can get the old lady to kick up some ching for a christmas present those big radius on your pic are pretty sweet those are one style im lookin at
Old Oct 9, 2009 | 06:33 AM
lionsm13's Avatar
lionsm13
Just look for a good 2-1 pipe off of ebay. You can find them(like a kerker) for a buck and quarter. It'll sound better and you might gain a few ponies besides.
jm04
Aug 11, 2009 04:45 PM
squirrelu
Feb 20, 2009 10:35 PM
bykrdan
Ironhead
Mar 26, 2008 12:15 AM
Mikeeeeeeeeee
Exhaust System Topics
Dec 13, 2006 10:06 AM
BaggerDave
Jan 13, 2006 10:57 AM
