Lowering Bars on Night Train
Old Oct 10, 2009 | 11:15 PM
Evoking's Avatar
Evoking
Default Lowering Bars on Night Train
Is there a way to lower the neck on my Night Train so the drag bars almost sit directly on top of the fork?
Old Oct 10, 2009 | 11:31 PM
DyNaBoB's Avatar
DyNaBoB
4" risers but any lower then that and youll hit da tank turning.................
Old Oct 10, 2009 | 11:36 PM
BoomerBob's Avatar
BoomerBob
Might be able to go a little lower if you turn the bars down.
Old Oct 10, 2009 | 11:46 PM
ScReaMnEagLE22's Avatar
ScReaMnEagLE22
4" risers will clear to the left side. Or when parked, but they wont clear the throttle cables on the right side.
Old Oct 11, 2009 | 12:23 AM
DyNaBoB's Avatar
DyNaBoB
yea tru ,but you never turn that sharp to the right driving jus parking..........but yes parking and turning all the way right the throttle cables will hit the tank
Old Oct 11, 2009 | 11:28 AM
imeric's Avatar
imeric
i have 4inch riser on my '06 springer with drag bars the throttle cables hit the tank and on the left the acorn nut form the mirror hit the tank.So i just turned the bars up a bit and it solved the problem.I am not sure if a night train would be the same or not.
Old Oct 11, 2009 | 02:03 PM
SpicOfTheDevil's Avatar
SpicOfTheDevil
want 2 to d same as u...during my research i found this:
http://www.oncycles.com/catalog.asp?r=1&pn=MCB00031
...their r intended for sportsbikes...d nt has 41mm fork tubes so could work...don't know if they r 1" in diameter...they would go right under d top triple tree...some mods to controls + grips r very probable...i'm gave up on d idea cause i'm too short to for the reach...it's just an idea
Old Oct 11, 2009 | 02:35 PM
DECON BLUE's Avatar
DECON BLUE
Unhappy
Been looking at this idea for sometime and I finally looked at the risers on the Screamin Eagle V-ROD Drag bike, the risers are only 1" high, but move the bars 2" forward. Did all the measuring and all looks good so I asked the parts guy at the Stealership for part # and prices. Well so ends the story, getting the parts was no problem, BUT the $$$$$ is insane. Like $450.00 for just the V-ROD parts not counting the shorter brake line you would have to have. So I am stuck with my 4"ers for now. Ride safe
Attached Thumbnails Lowering Bars on Night Train-100_0577.jpg   Lowering Bars on Night Train-100_0585.jpg   Lowering Bars on Night Train-100_0576.jpg
Old Oct 12, 2009 | 09:34 AM
platzbros's Avatar
platzbros
I just did this mod about 2 months ago....4" is about as low as you can go without something hitting. I installed 4 1/4" straight risers that are thicker than stock Harley risers so they look shorter than they actually are....you gain another 1/4-1/2" if you replace stock gas caps with recessed, pop-up style. If your doing this, I would also recommend replacing stock rubber riser bushings with the polyurethane bushings....I found that it eliminated that little bit of slop I could feel in the steering.
Supershane69
Feb 23, 2017 07:04 AM
night09train
Mar 19, 2010 02:33 PM
Will20204
Jun 10, 2009 12:49 PM
Method
Jan 8, 2009 01:20 PM
ZeroFiveFour
Feb 16, 2008 02:12 PM
