SE Air Cleaner
Old Jul 1, 2006 | 11:28 PM
Mike NY's Avatar
Mike NY
Default SE Air Cleaner
I'm looking to change out the Stock Air Filter with the SE Stage 1 kit. I want to also switch to a Round Air Cleaner cover. Will I be able to do this with this kit, and since the backplate looks round will I still be able to switch back to the original Oval cover one ?
Thanks
Mike
NY
Old Jul 1, 2006 | 11:48 PM
billvaughn's Avatar
billvaughn
Default RE: SE Air Cleaner
10-4....The stage 1 will fix both type covers and the backing plate remains the same
Old Jul 2, 2006 | 10:23 PM
bobros's Avatar
bobros
ORIGINAL: billvaughn
When I had my SE/AC installed by a dealer, I requested the round AC cover. They told me the round cover restricts the air flow and recommended I not change. Was I taken for a ride? I really wanted the old round look.
Old Jul 3, 2006 | 12:36 AM
billvaughn's Avatar
billvaughn
When I put the nostalgic round air cleaner on I didn't notice any difference.....
Old Jul 3, 2006 | 09:10 AM
Mike NY's Avatar
Mike NY
ORIGINAL: bobros
Dealer didn't say anything about that. He did add a gasket which he said ws needed on the inside of the cover though.
Mike
NY
Old Jul 27, 2006 | 01:00 AM
HARLEY100TH's Avatar
HARLEY100TH
I got a really dumb question: Are you supposed to oil the SE air cleaner like a K&N? Or, is it a dry filter?
Old Jul 28, 2006 | 02:47 PM
softail2005's Avatar
softail2005
Dry filter, I believe. You can buy the SE air cleaner kit from Eastern at a cheaper price $119, I paid full price of $139 at Harley. Eastern pays for shipping too. Its so easy to install yourself and good experience to do it yourself. Of course you have to add a fuel/air management system after you do this install if you are adding after market pipes. If no pipes the dealer must do a download.
I did the V&H pipes, the SE air cleaner and used the V&H Fuelpak. It was an easy install. Removing the old exhaust system took the longest and putting on the new was a bit of a juggle but its not hard, just takes a little time. I did not have the dealer do any downloads. The only advantage I believe is to change the rev limiter up a few hundred rpms.
Jay.fosman
May 28, 2018 01:15 PM
gkoerner
Dec 15, 2014 06:26 AM
BCKNBLK
May 22, 2012 06:26 PM
Jukebox
Aug 31, 2009 01:44 PM
SoCal Harley
Jan 9, 2005 06:05 PM
