Changing riser bushings on FL front end
Old Nov 5, 2009 | 04:07 PM
128auto's Avatar
128auto
Default Changing riser bushings on FL front end
Got some new riser bushings, do I need to remove the triple tree chromed covers? I am lazy lol
Old Nov 5, 2009 | 04:36 PM
oct1949's Avatar
oct1949
Not sure either,,,, me too..
Old Nov 5, 2009 | 04:38 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
You're a mechanic, are you not? It will most likely be easier if you remove the back covers, but maybe it can be done without taking them off.
Old Nov 5, 2009 | 04:49 PM
128auto's Avatar
128auto
looks like there is enough room there, yes I am a lazy mechanic lol
Old Nov 5, 2009 | 06:17 PM
jed1069's Avatar
jed1069
I had the back covers off mine. Just be careful not to smack the tank with a wrench.
Old Nov 5, 2009 | 06:27 PM
128auto's Avatar
128auto
Very good advice lol, dun ask how I know.
Old Nov 5, 2009 | 06:35 PM
DarkTrak's Avatar
DarkTrak
Don't tighten em' up too much either..............
Old Nov 5, 2009 | 07:58 PM
dugan's Avatar
dugan
how easy or difficult is it to change the bushings? details please.
Old Nov 5, 2009 | 08:16 PM
jed1069's Avatar
jed1069
I did mine while changing the bars so my front end was pretty torn down already.
I believe all you have to do is remove the 2 bolts on the side tins on the fork and 1 bolt on each of the back tins and you will have access to the bottom riser bolts.
Remove these bolts and the bars lift off. Then take a screwdriver to push out the old bushings, put new ones on and reassemble
Old Nov 5, 2009 | 08:36 PM
CSRflstc's Avatar
CSRflstc
I changed mine earlier this week. SUPER easy! Turn the bars all the way to the right to do the left, then turn hard left to do the right. I did one side at a time. Swing the bars outta the way enough to pull the rubbers out. I didn't pull the covers off. Careful not to bang a ratchet into the tank!
