burnout cycles lowering kit
Old Nov 23, 2009 | 08:18 AM
mke125125's Avatar
mke125125
Default burnout cycles lowering kit
its supposed to be here today. any of you fellas that have used this kit have any tips for install? easiest way to remove and replace shocks? any advice would be appreciated. this is my first harley (07 deluxe) and i try to do all my own wrenching but everything is always a first, thanks for any advice.
Old Nov 23, 2009 | 12:24 PM
twisted125's Avatar
twisted125
Rear kit? Bolts? not really familiar with their kit. BUT, I did a progressive rear bolt kit on my standard. Take your time, droppin the shocks is easy. Take some weight off the rear, and the bolts will come out pretty easily. Have a hydro press or something comparable to compress those things while you take the snap ring out. Ive got a thread saved that breaks it down a little better. If your kit is a front drop, then disregard this. Lemmy look real quick.
Old Nov 23, 2009 | 12:33 PM
twisted125's Avatar
twisted125
Yea, here it is. Look for my post mid way down.
https://www.hdforums.com/forum/softa...ml#post5528623
Old Nov 23, 2009 | 01:12 PM
DarkTrak's Avatar
DarkTrak
This is a post of pure lowering genius...there is no better way to lower a bike...LMAO........GAWD I was drunk!!
https://www.hdforums.com/forum/softa...-and-drop.html
Old Nov 23, 2009 | 01:32 PM
XARAN's Avatar
XARAN
The Burn Out Kit is very easy to install, they are lowering bolts that extend the the stock stem of the shock so you diont have to use a press to dissamble the shocks. Jut remove the shocks and thread the kit on to the end of the stock shock ( I would use red locktite) and reinstall.
This might help fo the shock removal www.fatbillscustoms.com
Old Nov 23, 2009 | 02:41 PM
mke125125's Avatar
mke125125
thanks for the replys, i shoud have been clearer. it is a rear kit that doesnt require disassembly of the shocks, you just gotta remove them to get it on. DarkTrack, i was kinda nervous about this and after seeing your post, now im scared sh%tless (kidding). thats some inovative stuff!
Old Nov 23, 2009 | 03:00 PM
DarkTrak's Avatar
DarkTrak
haha...Believe me, alcohol made that a lot more detailed than it needed to be. Pretty simple task.
Old Nov 23, 2009 | 03:08 PM
twisted125's Avatar
twisted125
^ haha innovative. I thought I was bein crazy puttin mine up in the air on a forklift, but YOUR technique was crazy. hahaha Trak, dude I totally forgot that was you. you muffed up a door frame trying to compress too didnt you? uhhh MKE, haha, lets see, advice, if you HAVE to rig something up to balance your bike on like Trak did, take your time and be careful. haha introduce some bondage to it just incase she loses her balance.
Old Nov 23, 2009 | 06:38 PM
bensonjv's Avatar
bensonjv
The burnout kit itself is very easy to install. The hardest part is pulling the shocks to install the kit; at least it was for me. Hard is probably the wrong word, or at least requires clarficiation. Its hard to get at the shock bolts, especially the rear ones. Its really hard to get them to break loose. From that point its just time consuming to get the bolts out. I have your standard MC jack and while it does a great job of hoisting the bike it does an equally good job of getting in the way. The combo wrench I had needed the bike up high to use it. High lift put the jack in the way.
While you are under there I recommend you get some nail polish or paint (a lighter color/white) and make a tick mark on the bottom of each shock. That gives you reference later on if/when you adjust stiffness. You'll be certain you are turning both shocks the same amount because you have a reference mark.
Old Nov 24, 2009 | 12:26 PM
mke125125's Avatar
mke125125
Thanks bensojv,I got the kit and the directions seem easy enough. However like you, once I get my lift under the bike I cant really see how Im gonna be able to get at the front bolts. o well them suckers are comin off there over the holliday weekend even if I have to print out darktraks step by step guide.
