Rocker swingarm on a Deuce?
Old Dec 4, 2009 | 09:33 PM
Speed's Avatar
Speed
Default Rocker swingarm on a Deuce?
I dont ride with anyone that has a rocker so I cant measure it myself but does anyone know if a rocker swingarm is the same width at the frame mount as a stock deuce swingarm.
basically, will a rocker swingarm bolt on a deuce?
Old Dec 5, 2009 | 09:14 AM
chopper blue deuce's Avatar
chopper blue deuce
Sorry, but nope. The rocker frame is wider at the mounts by a good bit. look at the oil tanks for a comparision. I have looked for a way for a while now!
Old Dec 5, 2009 | 10:48 AM
Speed's Avatar
Speed
thanks, thats kinda what I figured. I didn't think it would be that easy.
Old Dec 5, 2009 | 11:36 AM
WarriorHD's Avatar
WarriorHD
Sounds like its time for a new Rocker :-)
Old Dec 5, 2009 | 11:53 AM
Cheesecake's Avatar
Cheesecake
maybe you should look at a swing arm mounted fender....
CC
Old Dec 5, 2009 | 03:52 PM
Speed's Avatar
Speed
thanks CC but that wont help me hang a 240 on the back of my Deuce.
I'm trying to figure out a way to do it without it costing an arm & a leg.
Old Dec 5, 2009 | 04:59 PM
twiceretired's Avatar
twiceretired
I always assumed that if it was a Harley, it's gonna cost an arm and a leg no matter what!
Old Dec 5, 2009 | 05:53 PM
Speed's Avatar
Speed
HD = HUNDREDS of DOLLARS
Old Dec 5, 2009 | 07:50 PM
back again's Avatar
back again
any good fab shop can do what your asking I believe.All you have to do is tell them what you want to do and give them some dimensions.I've been looking at that and with some good measurement it's not a big job.Buy a used swing arm if you can to keep the cost down.Off set might mean a chain convertion also,but I think it can be done way cheaper than the kits you buy and be able to say you did it yourself.G.
Old Dec 5, 2009 | 08:19 PM
Speed's Avatar
Speed
without knowing for 100% thats more what I'm thinkin too.
I'm going to make a pit stop at the dealer and measure for myself.
there was recently a rocker rear end (swingarm/rim & fender) for under a grand on ebay.
well naturally it got me to thinking...
