The oil tank acts as sort of an oil cooler on Softails. I wouldn't want anything trapping extra heat in there.
That said, I wish somebody would make high temp decals that would stick and look good on an oil tank. Something like the crossbones oil tank (although the X-bones might be painted on). I bought one of those oil tank "trademark" decals and it only lasted a couple of days and left a smudge on the tank.
Any good Vinyl decals should work fine, the trick is put them properly when the tank is cold and let them dry up for a couple hours.
I used the decal installation kits from some decal company, there is a cleaning solution and application solution + squegee that will make sure there is no trapped air.
Looks good after 5 months and 6K so far.
Thanks for advice. My problem might be the wrinkle black paint on the tank prevents a good seal.
I am having a local Indie shop remove the oil tank, clean it up, have it powder coated gloss black, and re-install it for $374. Too much?
I am having mini apes (chimps) installed at the same time.
Yep. There are two bolts and a hose clamp that have to be removed from behind the splash pan. I pull my wheels off all of the time....throw her on a jack and pull them off!
Danny D
Way too much!
Don't be afraid to jump in there and get your hands dirty.
When you are all done you will have the satisfaction of knowing it was done right and done by you.
It's not rocket science. Just turn some wrenches and git-er-done.
The more you know about your bike the more confident you will be in it.
Why pull the rear wheel? I just changed the oil tank from chrome to wrinkle black on my 2005 Fatboy (yes, I need to update my sig), and I did not pull the rear wheel. I just put the bike on my J&S jack and took off the seat and splash shield. You can then easily get to the four bolts you need to remove on the backside of the tank.
Yes, the whole process is a little tedious (and messy). Put a towel in between the tank and the seat post for when you wiggle it out and back in (help save you from scratching the tank). You'll be squishing the tank back towards the thick wiring harness to get it out and then back into place.
Rear tire doesnt have to come off to do the job. I did mine with the rear tire still on and the bike on the jack. I forget if I used a ratcheting box wrench or my swivel head curved ratchet. That was definately my least favorite job on the bike to date though
