just saw the bike today. got it running on one crank. yay!
so the heads and cylinders with pistons for $200 today. (local guy named eric thanks!)
all i need to shop for is.
1. oil tank
2. bars & cables
3. floor boards
4. levers
5. grips
6. that part the sparkplug wire goes into that sends sparks. (distriburator?)
7 and the cover for it.
hydrolic or manual clutch. If hydrolic with will have a a fluid resivoir just like the one on your right hand for the brake. If it is a manual it will be a cable without the resivoir. anotother way to tell, squeeze it do you see a cable in it or does it press a piston? Im not positive but your clutch on left hand should be a cable and your break on right hand will be hydrolic.
