Front End Wobble
Old Jan 14, 2010 | 08:35 PM
OTTO's Avatar
OTTO
Default tire
I say it is in the tire .Needs to be balanced .
Old Jan 14, 2010 | 08:56 PM
meanderer's Avatar
meanderer
It could be all three - cupping, under-inflated, & out of balance. You may keep the tires at the proper psi, but you said you bought it used which means you couldn't know how diligent the former owner was in this. I'd replace the tire.
Old Jan 14, 2010 | 08:57 PM
Sagexpman's Avatar
Sagexpman
Originally Posted by GJC2
I have the same issue with my 06 Deluxe and I just had a new front tire mounted mid summer. The wobble is most noticable during deceleration from 40 to 30 mph. When I took the bike back to the dealer they said I needed to replace the rear tire ( which was true) they also found steering bearings a bit loose. I took the bike back and still had the issue. I kept the bike until the end of Nov. just tolerated the issue with hands on at those speeds. When I put the bike in for winter storage I told the dealer to please look again. The shop said they will check balance and if need be remount and rebalance. I won't know the outcome until March. I'd love to know your resolution if you get one before then.
GJC2
I will let you know if I find the solution, you do the same please
Old Jan 14, 2010 | 09:07 PM
Sagexpman's Avatar
Sagexpman
TX_Outlaw,
Gonna check this out over the weekend, makes sense. Thanks
Originally Posted by Tx_Outlaw
I had the same issue on an '05 Heritage Classic. Installed a mag wheel and new tire - same problem. Checked the pinch bolts on the trees and found a couple to be loose. Problem solved. Also check the steering head and fallaway.
Old Jan 14, 2010 | 09:18 PM
jed1069's Avatar
jed1069
I had the same trouble with my bike all last summer. I went round and round with tire balancing even went to dyna beads. None of this helped. Took it back to the dealer and they adjusted the head bearings and guess what it's gone.
Old Jan 14, 2010 | 09:51 PM
GJC2's Avatar
GJC2
6th Gear
Thank you jed1069 and TX Outlaw.
If I can remember by spring I'll let you know the end result. I'm a bit concerend now due to the fact that the HD dealer said they tightened the steering head bearings at my first complaint. I hope they check fall away at that time. I would be concerend about over tightened bearings might mask issue and premature wear of bearings. I made an assumption about something like the pinch bolts for the front end as a standard torque check during 10,000 mile maintenance. I'm still hoping for the out of balance tire. If my memory serves me right, which it rarely does, the issue seemed to arrive around the same time as the new front tire.
Hopeful.
GJC2
Old Jan 14, 2010 | 10:22 PM
oct1949's Avatar
oct1949
last spring a thread going around stated to check Ur spokes.
I did and had around 20 or so that was just a little loose.
And I had just had the 15 k service done... so much for that being done by the wrench..
I used a 4in adjustable wrench to snug them back up till the tinged the same at the others..
Old Jan 15, 2010 | 07:50 AM
djcustom1's Avatar
djcustom1
Good luck.
Old Jan 15, 2010 | 09:15 AM
heatstroke's Avatar
heatstroke
Originally Posted by Sagexpman
Hey guys,
I have an 07 Heritage with 15K miles that I recently purchased. I had the dealer preform a 10K service on it as it was not done by previous owner. I have noticed with the limited amount of riding that I have been able to do this winter that the front end has a tendency to wobble at speeds between 40 - 45 MPH. If I loosen my grip on the bars or remove them it is much worse. At higher or lower speeds no problem at all. Not sure if it would make a diff or not but the front tire is at approximately 3/32 and will need to be replaced soon. I told the dealer about it prior to the 10K service and they did not find any issues with fork bearings. Any ideas?
Thanks for the help....Rick
My bike just had it's 1000 mile service,mine also has the same wobble between 40-45 mph. after they put grease in the neck bearings some of the wobble went away.He said if that did not fix the problem he would rebalance the front tire.
Old Jan 15, 2010 | 09:19 AM
bagga's Avatar
bagga
loose rear spokes is the first thing i would check.
