Front End Wobble
Old Jan 14, 2010 | 01:20 PM
Sagexpman's Avatar
Sagexpman
Default Front End Wobble
Hey guys,
I have an 07 Heritage with 15K miles that I recently purchased. I had the dealer preform a 10K service on it as it was not done by previous owner. I have noticed with the limited amount of riding that I have been able to do this winter that the front end has a tendency to wobble at speeds between 40 - 45 MPH. If I loosen my grip on the bars or remove them it is much worse. At higher or lower speeds no problem at all. Not sure if it would make a diff or not but the front tire is at approximately 3/32 and will need to be replaced soon. I told the dealer about it prior to the 10K service and they did not find any issues with fork bearings. Any ideas?
Thanks for the help....Rick
Old Jan 14, 2010 | 01:22 PM
Maimas's Avatar
Maimas
Sounds like the wheel may be out of balance. Does the tire have any cupping or uneven treadwear? Does this happen while braking or does it get worse? How does the rotor look?
Old Jan 14, 2010 | 06:41 PM
sancho_panza's Avatar
sancho_panza
-Not trying to be a wiseguy, but I always double/triple-check the tire pressure first. Then, the wheel balance/loose spokes. Good luck, and please post the culprit when you find it.
Old Jan 14, 2010 | 07:03 PM
djcustom1's Avatar
djcustom1
Sounds like wheel out of balance to me.
Old Jan 14, 2010 | 07:20 PM
Sagexpman's Avatar
Sagexpman
Thanks for the reply guys. I know the tire pressue is correct and there is no cupping or visible problems with the tire. I will need to replace it this riding season so I will make sure that it gets balanced at the same time. Rotors are fine and no problems when braking. What is the best way to check for loose spokes? Just put a spoke wrench to it and see if any are loose?
Old Jan 14, 2010 | 07:27 PM
sancho_panza
Yes, that's what I'd do. I don't have a torque-wrench for spokes, so I just check to see if any are obviously loose. You might be surprised and find a couple. I did on my Nightster occasionally. I'm just guessing that you'd have to have one or two pretty loose to put the wheel out of true.
-Ron
Old Jan 14, 2010 | 08:09 PM
silvrbill's Avatar
silvrbill
Replace tire...no more wobble.
Cupping can be hard to see at the beginning but you can feel it.
Use your hands, not your eyes.
Old Jan 14, 2010 | 08:13 PM
Sagexpman's Avatar
Sagexpman
Thanks silvrbill. I will check it out
Old Jan 14, 2010 | 08:29 PM
GJC2's Avatar
GJC2
6th Gear
I have the same issue with my 06 Deluxe and I just had a new front tire mounted mid summer. The wobble is most noticable during deceleration from 40 to 30 mph. When I took the bike back to the dealer they said I needed to replace the rear tire ( which was true) they also found steering bearings a bit loose. I took the bike back and still had the issue. I kept the bike until the end of Nov. just tolerated the issue with hands on at those speeds. When I put the bike in for winter storage I told the dealer to please look again. The shop said they will check balance and if need be remount and rebalance. I won't know the outcome until March. I'd love to know your resolution if you get one before then.
GJC2
Old Jan 14, 2010 | 08:34 PM
Tx_Outlaw's Avatar
Tx_Outlaw
I had the same issue on an '05 Heritage Classic. Installed a mag wheel and new tire - same problem. Checked the pinch bolts on the trees and found a couple to be loose. Problem solved. Also check the steering head and fallaway.
