Progressive Drop in Springs and Going Lower
Old Mar 10, 2010 | 09:32 AM
LooseMoose's Avatar
LooseMoose
Count me in as well.... This is very relevent to my intrests!!
Old Mar 10, 2010 | 09:49 AM
Ash16's Avatar
Ash16
At first I was interested in the thread but then I got distracted by Storys Hawaiian surfer girl. DAMN!!!!
Old Mar 10, 2010 | 10:35 AM
story808's Avatar
story808
Haha... I riding this coming week end and then I'll do the install. I have a 3* rake on the front already so I'll start at 4" with the PVC. Then see where she sits but I will measure before and after for you guys.
Old Mar 10, 2010 | 11:20 AM
Rick101285's Avatar
Rick101285
Sorry to keep you guys waiting. I am going to pull the front end apart this weekend and see what i can do. gonna cut it down to 3.5". Will let you know
Old Mar 10, 2010 | 11:29 AM
cryan9's Avatar
cryan9
Good Thread because I was wondering the same thing. I just lowered my front with the drop in kit this past weekend. I used the standard 4.5" spacer and was wondering if I could go below the 4". So what did I do? I called Progressive. They told me the more you cut the spacer the softer the ride will be. They also told me not to go beyond the recommended 4". He said if I cut too much and the front end is too soft, go to the local store and pick up some more pipe and start over. So if anyone goes beyond the 4" let us know how it rides because we all want to know.
Old Mar 10, 2010 | 01:34 PM
story808's Avatar
story808
When you went with the 4.5 did you notice any lowering in the front? How many inches did it go down? Like I said before my friend went down to 3.5 and he said it's still stiffer then it was before the drop in kit?
Old Mar 10, 2010 | 01:51 PM
priceamp's Avatar
priceamp
Originally Posted by cbr310
I have a 03 train and got the kit 2day. Do I need to take the forks off?
Can somebody answer this question? I’d like to know too. The on-line pdf file instructions says to remove the forks, but I don’t see why you would have to remove the forks for the drop-in kit. Thanks.
Old Mar 10, 2010 | 03:51 PM
cryan9's Avatar
cryan9
Yes it lowered it around 1.5". I want a full 2-2.5" though. The top of my fork boot to the bottom of the tree is now 7" I believe it use to be 8.5" or 8, I'm not sure. If it was 8 then it lowered it an inch.
Old Mar 10, 2010 | 03:56 PM
cryan9's Avatar
cryan9
Yes you do have to take off the forks because you have to get to the top of the forks. Here is what I did. remove the wheel and fender. Zip tie the brake caliper to the frame at the top of the down tubes. Unscrew the screw at the top of the trees. Loosen the pinch bolt from behind the lower tree. Slide out the tubes. Loosen the plug on top of the forks that you will see after you remove them. Keep down pressure on it because it will spring up a little. Then take out you old springs, put the new ones in and put it all back in reverse order. It is really not as bad as it seems. Only took about 45 minutes to complete.
Old Mar 10, 2010 | 04:51 PM
cbr310's Avatar
cbr310
was that measurement when it was on the ground sitting level? Mine is 6 3/4 from top of fork boot to bottom of triple tree. Think the front might of already been lowered. When I bought itbut not sure.
