Help on Exhaust
Old Feb 24, 2010 | 01:57 AM
SLWRDE's Avatar
SLWRDE
Default Help on Exhaust
I have a stock 09 Deluxe and I found some Martin Bros exhaust online for a really good price, but they do not come with O2 bungs. What would be my choices as far as installing O2 bungs or can I just eliminate the O2 sensors. I am also going to be installing a Heavy Breather intake as well. Thanks everyone for your help.
Old Feb 24, 2010 | 02:13 AM
IronAss's Avatar
IronAss
I'm not really up on the FI bikes. (always had a carb) but I'm thinkin you probably need the o2 sensors for the bike to run right. I might be wrong.
Old Feb 24, 2010 | 02:19 AM
IronAss's Avatar
IronAss
Just did a quick check and found this. Guess you don't have to use the o2 sensor.
http://www.aliencycle.com/fuelinjection.html
Old Feb 24, 2010 | 07:22 AM
RHillbilly's Avatar
RHillbilly
Get a PCv and you wont need the o2 sensors
Old Feb 24, 2010 | 07:27 AM
MCSarge's Avatar
MCSarge
Your going to have to use a fuel controller of some sort if you get rid of the sensors. But for a minimum cost you can have the bungs welded in at any muffler shop. I have welded a few in for friends it's not that hard. Tuning this setup may be a chore as most of the pipes from them I have seen have really short runners, and you may loose a lot of bottom end.
As for the martin brothers exhaust I have found most of them to be kind of short and and I think they are going to be really loud and right under you ear. Most of them I have seen have been at shows and not on bikes that get ridden regularly. Just my .02 Good luck on your project
Old Feb 24, 2010 | 03:15 PM
sgod1100's Avatar
sgod1100
Sorry about highjacking the thread, but I tried sending you a PM about the spike air filter, but it said that "you chosen to not receive pm's or " cannot receive them". Did you still want it?
Old Feb 24, 2010 | 03:18 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
The Martin Bros pipes are likely to provide poor torque due to the short length of them. You can use a PCV to eliminate the 02 sensors.
Old Feb 24, 2010 | 03:21 PM
RaaDeuce's Avatar
RaaDeuce
Power Commander eliminates the O2 sensors anyways, so you'll be alright.
Jeffrey Hatch
Apr 24, 2019 09:27 PM
leafman60
May 9, 2016 08:54 AM
PRODUCTofNJ
Sep 22, 2014 08:30 PM
The Ground Truth
Feb 23, 2010 09:12 PM
JekyllnHyde
Aug 11, 2009 05:34 PM
