Engine dieing
Old Mar 6, 2010 | 10:49 AM
Wpittman's Avatar
Wpittman
Default Engine dieing
i know this is not the proper forum for this question but this section gets a lot of visits. riding yesterday and last nite my engine would die every time i went to idol at intersections. Now the temps were around 28 - 30 degrees. This was on a 2 and half hour trip at speeds ranging from 55 - 65 mph. (YEA IT WAS COLD) Does this have anything to do with it. Its an 08 fatty with 21,000 miles on it with no previous issues. Whats going on help me if you can.
Old Mar 6, 2010 | 11:11 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Try cleaning you Idle Air Control in the throttle body. Also see this thread. https://www.hdforums.com/forum/engin...e-problem.html
Old Mar 7, 2010 | 07:53 AM
tk353's Avatar
tk353
bad gas, i also had that once and just turned off the bike and then started again and it went away. computer glitch or sensor issue
Old Mar 8, 2010 | 07:09 AM
Wpittman's Avatar
Wpittman
bike has been sitting and maybe second tank of gas since winter. can a diagnostic be ran through the dash to find codes on the o8 softtail without going to the dealer
Old Mar 8, 2010 | 08:12 PM
Wpittman's Avatar
Wpittman
ttt thanks 4 input
Old Mar 8, 2010 | 10:03 PM
jimmers1817's Avatar
jimmers1817
I had a similar issue with my 08 Heritage. Come up to a stop sign, pull in clutch, bike would stall. Start it back up with the start button and next stop it would do it again. I found if I turned the switch off and restarted it I wouldn't have the problem for a much longer time. Finally took it to the dealer and they said it needed an updated flash to the ecm. Haven't had the problem since. Also corrected a pinging and intermittent high idle problem I was having.
bmorebhoy
Sep 29, 2010 03:28 PM
wildroot
Aug 21, 2010 08:06 PM
sierra_93955
Exhaust System Topics
Aug 3, 2009 09:41 PM
cholmes
Jul 24, 2009 03:48 PM
fkstk181
May 30, 2007 04:47 PM
