Hi guys, i have just received my console insert for my Rocker 08, the problem is that the instruction booklet wasn't inside the box, so I do not how the hell I can install it, any one of you can give some clue?
Tx a lot,
Ride Safe
Tx a lot,
Ride Safe
Have you pulled out the stock insert? If not take a small screwdriver and slip it under the insert and PULL HARD.. It's glued down good.. Once it's out line up the new one and install it..
No, there's no need to heat the old one as you are taking it off. Like they said before, just pull hard....I used a towel around the end of my screwdriver when i was taking mine off, so i didnt scratch my paint.
