97 heritage intake?
Old Jul 31, 2006 | 10:33 PM
twodogs35's Avatar
twodogs35
Stage I
Default 97 heritage intake?
Been trying to install the intake manifold on my heritage using the service manual instructions. I've taken it apart and put back together four times now and get leaks everytime. Used new seals and flanges each time and cleaned everything spotless. Installed the manifold first, finger tight, then put on carb seal and carb. Tightend carb and backing plate, then tightened manifold bolts, slowly and as even as possible. Leaks every time using carb cleaner to check for leaks. When I give the back intake seal a good shot of carb cleaner, the engine dies, indicating a leak. On the first three attempts installed seals dry. On the last attempt I put I very light coating of vaseline on seals(per HD mechanic instructions). PLEASE HELP. What am I doing wrong.
Old Aug 2, 2006 | 12:40 PM
Tucker99's Avatar
Tucker99
Default RE: 97 heritage intake?
Sounds like you're doing everything right twodogs. Let us know what you finally do to resolve the leaks. I have a '98 and may have to take the intake off sometime.
Thanks,
Tucker
run1fsr
Nov 5, 2012 06:56 AM
95yj
EVO
Sep 5, 2011 09:52 PM
sheem2153
Exhaust System Topics
May 13, 2010 10:16 AM
softail 99
May 10, 2007 12:50 AM
Skip
Aug 28, 2006 10:08 PM
