Oil consumption
Old Mar 18, 2010 | 08:48 PM
Blk and Chrome's Avatar
Blk and Chrome
1qt in a 1000 miles is a standard of the auto and motorcycle industries. If its more they will find and repair it under warr if you use less them it is considered normal
Old Mar 18, 2010 | 09:05 PM
rickb's Avatar
rickb
1 qt every 1000 miles is normal? So if you follow the manufactures recommended oil change mileage you would be out of oil at 3000 miles and you still have 2000 miles to go before an oil change. So than what???? You need to have a leak down test preformed and find out what is leaking it can only be one of two things the rings or the valves.
Old Mar 19, 2010 | 12:14 AM
Other Sheep's Avatar
Other Sheep
07 Heritage with 26,000 miles. I just did my oil change and 25 and it didn't use even a fourth of a quart since 20,000 miles. I'd say something is wrong. It's either got too much oil to begin with or the rings never took a seat.
Old Mar 19, 2010 | 02:27 AM
Rakthi's Avatar
Rakthi
It does say in your manual to check your oil level at regular intervals and if needed to add some ...
On my 2009 bike the level has dropped about a quarter of an inch over the past 4000 miles. The BMW I had before used to have no problem consuming a quart in 1000 miles. Even stated to be normal in the user's manual.
Old Mar 19, 2010 | 04:37 AM
Blk and Chrome
It's up to you to ck the oil before you ride. That way you will never run out of oil. Everything you drive isn't maintance free. One thing to remember is if you run it out of oil it is your fault.
Old Mar 19, 2010 | 07:01 AM
Tom84FXST's Avatar
Tom84FXST
Originally Posted by goatdriver
I know they have a bulletin out that says as much as a quart per 1000 miles is normal,
If you are indeed using a quart per 1000 miles, it is not normal. The bulletin is so they don't have to fix them. If you can find a good dealer, (good luck with that) they will work with you to find the problem, but warranty won't cover it because of the bulletin. It could be something simple like the breather system. I have seen high oil consumption with synthetic oil...won't let the rings seat...so if you are running that stuff, I would run regular oil at least until you solve the problem. FYI if that much oil is getting past the rings, a lot of the HP you are paying for is going to. You may have to do your homework and go after warranty on low compression or HP and not just oil consumption because the MOCO will do everything in their power not to fix it ...which is kinda sad.
Old Mar 19, 2010 | 07:43 AM
tmitchellof PG's Avatar
tmitchellof PG
Is it possible that you are overfilling the oil? You should only check the oil level after the engine has been brought up to operating temperatures and been shut off for 5 minutes or so. The bike should be on the jiffy stand when checking the oil level.
If you are not checking the oil level using this method, you are probably overfilling it with oil and the excess is being sucked through the air intake and burned by the engine.
Tom
Old Mar 19, 2010 | 06:58 PM
waxer's Avatar
waxer
Check your plugs for oil deposits, if it's the rings or valve seals it should show up there. If everthing looks OK there you need to check for sumping. I had an 05 that was an oil burner & the dealer also gave me the crap about a Qt in 1000 miles was normal until I showed him the plugs then he agreed there was a problem. My experience is that the motor will burn some of the oil which passes thru the air cleaner but won't if it's a oil burner.
Waxer
Old Mar 19, 2010 | 09:02 PM
soft 02's Avatar
soft 02
I got 64,000 miles on my 07 and it has never burned a drop. Not even durring break in and ride her hard!
Old Mar 19, 2010 | 09:40 PM
j1mmy's Avatar
j1mmy
i have an 01,with 50k miles, it hasnt used a drop since i last changed it a year ago
