Just had the Red Shift 575's put in my 08' Fat Boy and love it!
Also have the Heavy Breather and used the FuelPak before the cam change. Don't think the FuelPak will work well if you change cams, the list they have codes for is pretty short :-(
The Red Shift 575 works well with the rest of the motor being stock. Not that agressive of a cam, but improved the torque and increased what I call "ridability" on the highway.
I had the Thundermax Autotune put on at the same time. Only thing I can say now is I wish I had done it a year ago before buying the FuelPak.
FYI, the Thundermax, Red ShHift 575 cam, and SE adjustable pushrods cost me about $1,450 including labor. This was done at Newburgh Motorcycle Service, which is just NE of Evansville, IN. Owner of the shop is Mike Loehr.
All said and done I spent $1200 doing mine myself. I actually spent several hundred more, but some of that I could have saved if I had planned better and not had a few hickups. Cams, bearings, lifters, pushrods, gaskets, PCV premapped, etc. I also bought a bearing puller, motorcycle jack, inch pound torque wrench....all stuff I have now, but still ended up costing more than I planned. I love the cams though. Don't be afraid of a bigger cam.
do U know we have a Dyno thread in here for softy's...
Its in the sticky section on page one in here.
My dyno sheets for the 26h's I had installed are the first post in the tread...There great for 2up
Also the SE 203's, SE204's/4*advance, crane 300, Dave Mac-tc510, HQ tc500hc, S&S510c, will give good performance for bolt-ins.
For me after studying them I felt the 26's were as good as any but I liked the Andrews a llitte better..
Woods cams always seem to be the top in performance, but at a price.. there 6-6 is sometimes installed with 4* advance to move the line more to the left.
I just dropped 204 cams in and am ready to fire it up today after loading a new map. What does the 4 degree advance do for you and what does it entail?
I think $800.00 is a great deal concidering.....I had the SE211 cams installed for $667.85, SE Pro tuner $459.95, SE Stage 1 a/c $139.95, 2 spark plugs $7.90 and the dyno $280.00 for a grand total $1684.86 with tax. I was not charged for the adjustable pushrod kit($146.95) You already have the exhaust and the a/c.. the fuel pak(junk)won't adjust enough for cams so you will be somewhere in that ballpark when you do the cams and a good tuner and don't forget the adj pushrods to cut some of the cam labor back... By the way, The SE211 cams are F###in awesome!! The torque is strong with my heavy bike even with stock compression.. Good luck.
I put in se204's I rode about 100 miles today and I'm happy with them. +1 on a 4 degree advance gear, wish I did that but I'll live with what I got for now.
Dude what was the final dyno numbers with the se204? that is gonna be my next mod.
The 4 degree advance gear will bring the torque curve in sooner. The 204's do have a point where they come in and since I don't have a tach I am thinking it somewhere around 3000 rpm. When it does it pulls real good.
