Cam upgrade questions
Old Mar 19, 2010 | 12:14 PM
pawpaw01's Avatar
pawpaw01
Default Cam upgrade questions
I need some advice and help from the cam gurus please. I have a 2008 FXSTC with a stage 1 (V&H Big Shot Staggered, K&N stage 1 air filter kit, and V&H FuelPak). I am wanting to upgrade the cams to increase low end & mid-range power. I don't often run in the higher RPM range so I really am not interested in a big cam... My questions are; 1- will I need to install a gear driven cam setup or is the chain drive sufficient? 2- will a Woods TW 6-6 or a Andrews 26H work well without doing any headwork or altering the stock compression ratio? I appreciate any advice & help you guys can offer, including cam selection...
Remember, Ride Safe...
Old Mar 19, 2010 | 12:20 PM
chuckm081357's Avatar
chuckm081357
6th Gear
Just had the Red Shift 575's put in my 08' Fat Boy and love it!
Also have the Heavy Breather and used the FuelPak before the cam change. Don't think the FuelPak will work well if you change cams, the list they have codes for is pretty short :-(
The Red Shift 575 works well with the rest of the motor being stock. Not that agressive of a cam, but improved the torque and increased what I call "ridability" on the highway.
I had the Thundermax Autotune put on at the same time. Only thing I can say now is I wish I had done it a year ago before buying the FuelPak.
Old Mar 19, 2010 | 12:31 PM
Rail's Avatar
Rail
You don't need to worry about gear drive with the new twin cams.. The new chain drive system is pretty good plus there's a possible issue with crank run out on them so the gears could actually be more of an issue than they would help..
There are a lot of bolt in cams.. SE204, Woods, Andrews, HQ, TMan, Red Shift, etc..
Do your research and look for dyno's for similar builds to yours using the cams you're interested.. You'll get a headache after awhile.. lol
Old Mar 19, 2010 | 01:01 PM
beaureed445's Avatar
beaureed445
As Rail has already said, the newer chain drive (hydraulic) is a good set-up. It's far superior to the old chain tensioner set-up. As far as cams go, I'd seriously consider the Woods TW6-6, but add a 4* advance gear to compensate for your lower compression. If you don't want to do that, take a look at the HQ 500 or T-Man 525.
Old Mar 19, 2010 | 07:05 PM
RHillbilly's Avatar
RHillbilly
I have the Woods 408-44 in my 09 fatboy have it advanced 4 deg sounds and runs awesome,I wouldnt put in anything but a Woods
Old Mar 19, 2010 | 07:25 PM
DarkTrak's Avatar
DarkTrak
What was the start to finish cost to do your cam set up? gaskets, oil, the kit itself...everything...?
Old Mar 19, 2010 | 07:34 PM
Blk and Chrome's Avatar
Blk and Chrome
I put in se204's I rode about 100 miles today and I'm happy with them. +1 on a 4 degree advance gear, wish I did that but I'll live with what I got for now.
Old Mar 19, 2010 | 07:38 PM
mike06train's Avatar
mike06train
You should pay around $800 for a set of bolt in cams installed and a dyno tune. You'll prolly have to swap out that fuel pack though and thats going to add some bucks.
Old Mar 19, 2010 | 10:53 PM
kiwideuce's Avatar
kiwideuce
mines in at the moment!going 1550 and tw37 andrews cams! cant wait!!
Old Mar 20, 2010 | 10:59 AM
RHillbilly's Avatar
RHillbilly
cam and advance gear 557 shipped,adj pushrod 127 shipped from Zannottis,had a 20% off coupon on the service so it cost 460 to have it installed and dynoed
