Brake noise
Old Aug 3, 2006 | 08:36 PM
greenscrambler's Avatar
greenscrambler
Default Brake noise
Got about 2500 mi on my 06 heritage classic. sems like the more miles the louder the rear brake noise. Any ideas? Thanks
Old Aug 4, 2006 | 12:31 AM
T Tommyt's Avatar
T Tommyt
Default RE: Brake noise
Haven't heard mine or any post's here on the REAR
but the Front Brake seems to be under some kind of quiet recall
you may want to do a Search or ask on the General Info Page
Old Aug 4, 2006 | 12:57 AM
wildman67's Avatar
wildman67
maybe it is just me! but i rest my foot! heel on board toe on highway peg! but i tend to drag my foot on pedal!
Old Aug 4, 2006 | 03:22 PM
Clear Water WI's Avatar
Clear Water WI
Greenscrambler,
I have an 06 Classic with 3K and just had the exact problem with my rear brake. I tried everything except the most logical. I thought I adequately cleaned the brake caliper/rotor during my regular soap and water washings but I wasn't doing enough. My wife suggested cleaning them with brake cleaner but I quickly dismissed her suggestion thinking she didn't have any idea. Well, after a few days, I swallowed my man pride and went to the automotive store and picked up a $2.00 can of brake cleaner spray. I sprayed the entire can on the both front and back (the front brake had started to squeal as well) and you would not believe the gunk that came out. My garage floor is still stained from it but I don't care because it absolutely solved the problem! The only thing I caution about is the brakes were extremely unresponsive for about 5 to 10 minutes afterwards. I slowly drove to a nearby parking lot and worked the brakes for a few minutes until they came back in full strength and without any squeal. Five hundred miles later and they are still squeal free. Don't get brake dust wheel cleaner but actual brake cleaner. It's cheap and it worked for me....good luck!
Old Aug 4, 2006 | 03:42 PM
Babs's Avatar
Babs
Warning.. The cleaner smell will give ya one serious buzz! hehe Use in a ventilated area.
Reminds me.. I need to pull my pads and clean them.. Mine squeal like a banshi also when I slow up close to a stop. Embarrassing.. sounds like an old army jeep.
I remember in the ole' trusty "fix my hog" video dvd where they also took a file to the edges to knock down any "burrs" along the edges as well.
Old Aug 4, 2006 | 10:38 PM
greenscrambler
Thanks for the help. I will try the cleaner. Hate that noise. (fingernails on a blackboard)
Old Aug 4, 2006 | 11:16 PM
Mike05's Avatar
Mike05
Babs is correct about using in a well ventilated area. The brake cleaner is about the same stuff and dry cleaning fluid. I don't think is is flamable, but it packs a whollop in a closed room. And in concentration, it could be fatal.
Old Aug 5, 2006 | 09:26 AM
Grey Biker's Avatar
Grey Biker
You guys can keep cleaning your pads with whatever you want and the problem will keep comming back as dust and dirt builds up. We had the same problem with a Road King with the duell front rotors ,you can imagine the squeel. A set of aftermarket pads eliminated about 75% of the noise then the rotors were reversed, this totaly eliminated all noise......
Old Aug 5, 2006 | 10:09 AM
T Tommyt's Avatar
T Tommyt
Yep thats what I read on here or some where
SGMongoose
2014-2024 Touring Models
15
Nov 27, 2015 06:55 AM
Skeet7373
37
Nov 20, 2012 03:06 PM
Uhmerikan
May 23, 2008 05:04 AM
ashleyb8
Apr 10, 2008 07:17 PM
Tommy Meisel
Mar 5, 2006 01:27 AM
