Samson pipes on Deluxe Question (Update)
Old Aug 4, 2006 | 07:56 PM
Bluerose
Guest
Posts: n/a
Default Samson pipes on Deluxe Question (Update)
For those of you that have Samson True duals do you notice that bike seems to lobe and a bit more vibration? I hadn't notice vibration at highway speeds before. Riding just feels different since I've changed pipes.
Then again it could just be my imagination but I don't think so.
Old Aug 4, 2006 | 08:13 PM
softail2005's Avatar
softail2005
Default RE: Samson pipes on Deluxe Question
If those are the long pipes with the fins on the end make sure you have the fin turned into the airflow otherwise the bike will try to "twist in the wind! " Ha! Ha! Just kidding!
If you are getting lopeing at certain speeds I think you need to check the fuel/air mix for a too lean situation. Vibration is another unrelated problem and I would take it very seriously. Check the tires by rubbing your hands around all surfaces to look for any bumps or out of round condition. Check the spokes to make sure they are not loose, all bolts on engine, frame. Drive belt to make sure its running straight and has not had damage on the lugs inside belt surface.
Make sure you have the bolts tight where the pipe attaches to the exhaust ports. The gaskets can shrink a bit and you may need to check to make sure they are properly torqued. Check where the pipes are bolted to the frame rail, and mufflers. Thats about all I can think of. Hope that helps.
Lee
Old Aug 4, 2006 | 09:49 PM
Bluerose
Guest
Posts: n/a
ORIGINAL: softail2005
Lee
Oh crap...I totally forgot to check the bolts after running it for a while...It just started feeling funny after the last long ride...That's probably it. Thanks...I'll check them when I get home.
Old Aug 10, 2006 | 04:46 PM
anubisss's Avatar
anubisss
How are those fishtails? I was thinking about getting some but wasn't sure how it would affect my powerband. Do you feel like you lost any power? Low end maybe, or do you have a sert or pc3? I am quite curious as I love the way those true duals look, but am concerned about having to add anything else. Do you have a download, also? Name:  n005.jpg
Old Aug 10, 2006 | 07:07 PM
Bluerose
Guest
Posts: n/a
Yes I have the sert. I put them on just before 1000 miles and didn't feel much of a difference.
Old Aug 20, 2006 | 03:56 AM
Bluerose
Guest
Posts: n/a
Default RE: Samson pipes on Deluxe Question (updated)
I found my vibration. I stopped at a mechanic today and had him take a quick look. Turns out the fishtails were fishtailing a bit and touching the back bracket on the right hand side and tuching a bolt about halfway up the pipes.
Put a couple of washers in on the bolts that hold the muffler between the muffler and the bracket fixed her right up. Sometimes it the stupidest things.
Old Aug 20, 2006 | 04:15 PM
sfcmo357's Avatar
sfcmo357
sounds like a cheap fix
Old Aug 20, 2006 | 10:18 PM
Bluerose
Guest
Posts: n/a
Yeah amazing it didn't cost $100
Old Aug 20, 2006 | 11:40 PM
LJC's Avatar
LJC
6th Gear
Default RE: Samson pipes on Deluxe Question (Update)
Just say it. You realise it's not right! Don't be passive/aggressive?
lloyd123
Mar 24, 2016 09:50 PM
jgann
May 6, 2013 11:56 PM
05LowRider
Dec 11, 2012 05:20 PM
305gator
Nov 24, 2009 05:55 AM
bambamblazer
Jan 27, 2009 05:19 PM
