5 Broken Sprocket Bolts
Old Nov 9, 2010 | 04:51 AM
03hdfatboy's Avatar
03hdfatboy
I've done it twice, 1st time stock bolts that had never been removed, the second time I had brand new grade 8 bolts. This time I redrilled the holes and tapped 'em to 1/2" x 13. It should be good now.
Old Nov 9, 2010 | 07:06 AM
Bugsplat's Avatar
Bugsplat
I replaced my rear sprocket for the HD chrome version which came with new bolts - bolted into a Ride Wright wheel. I was paranoid about the bolts coming loose and shearing off by the swing arm. I used red loctite and torque'd them down as per the instruction sheet which had a higher torque than what the manual specified. 1,000 miles later (which included 600 miles at above 70 mph) no problem with loose bolts.
Old Nov 9, 2010 | 08:15 AM
LocoPilot750's Avatar
LocoPilot750
It's a good idea to "pre-flight" these machines just as you would an airplane. The pilots on this board know how to do that each time they fly. A post-flight is a good idea to. You don't have as far to fall, but you can be just as dead.
Old Nov 9, 2010 | 08:25 AM
hizzzum's Avatar
hizzzum
Stage I
you should all ways inspect the bolt threads and the hole the bolt came from, any time you remove a bolt.
Stinger1
Apr 12, 2025 07:49 PM
Big Blue
Aug 28, 2012 04:33 AM
Big Blue
Aug 27, 2012 11:58 AM
anubisss
Jul 19, 2011 04:28 PM
bodyman0
Sep 13, 2007 04:17 PM
