where for tires?
Old Aug 5, 2006 | 06:03 PM
IRready's Avatar
IRready
Default where for tires?
Should I go to the dealer or is there a better alternative for tires? My tires are over 10K and needs replacement. I am not sure if I should go with the same tires or are there better choices then DUNLOP'S? Thanks for any advice.
Old Aug 5, 2006 | 10:52 PM
billnourse's Avatar
billnourse
Default RE: where for tires?
I run stock Dunlops on mine. Get them from American Motorcycle Tire. I take the tire off have an independent mount and balance the new tire, and then I put it back on. Saves about 75.00 per tire.
Regards,
Bill
Old Aug 6, 2006 | 02:01 AM
IRready's Avatar
IRready
Thanks for the reply Bill.
Old Aug 6, 2006 | 03:08 AM
IRready's Avatar
IRready
Bill,
Do the tubes need to be replaced as well? I have spoke rims so I presume I have tubes, even thought the tires say tubless??
Old Aug 6, 2006 | 10:48 AM
GPLRJBRAZIL's Avatar
GPLRJBRAZIL
Try Metzeler
Old Aug 6, 2006 | 11:15 AM
uj034's Avatar
uj034
http://www.americanmototire.com
Old Aug 6, 2006 | 04:00 PM
billnourse's Avatar
billnourse
I always replace the tubes, as one usually gets torn while taking them out anyway, plus they wear inside the tire, just like the tire wears.
Most HD shops will not replace a used tube in a tire when they do the change.
Regards,
Bill
Old Aug 6, 2006 | 04:45 PM
nikonf8's Avatar
nikonf8
I just bought a spear set of oem dunlop's from M & M cycle on line had 30% off I paid $255.00 to the door for the set 419 624-8739 ask for mark
slowrollin
Jan 11, 2023 07:17 AM
Darkrider1
Jul 31, 2011 09:08 AM
c50plus
Jun 25, 2011 03:47 PM
rdam
Mar 8, 2011 09:43 AM
brutalbrad
Jun 29, 2010 06:46 PM
