Calling all FatBoy Lo Owners
Old Jul 30, 2012 | 03:21 PM
  #7771
DeeRides's Avatar
DeeRides
Originally Posted by iamawakenowtvm
...<snip>
This can build up on your tire and cause you serious problems...Or worse, you stop at a red light/stop sign and put your boot down on this, or the thermoplastic that the "pavement signs" are made with...It only takes one time for it to happen and you never make the mistake again...If you are not injured, your bike is...If both you and the bike are not injured, your pride is forever injured by dropping your bike in heavy traffic...I personally have tested this logic and failed...It hurts...
I've never thought of or heard this about the thermoplastic 'pavement signs'. Thanks for that tip! I've slipped on them in parking lots with wet shoes so it makes perfect sense! I'll be watching for that at stops.
Old Jul 30, 2012 | 03:44 PM
  #7772
TNB's Avatar
TNB
I have learned to do the same...I have stock cap gauge and stopped again today to get gas...My gauge showed at the bottom, fueled up, and it only took 2.9 gals...
"Confused" I looked at the range indicator and it was consistent with only 2 gals used...
I replaced the stock fuel cap gauge with the blue LED flush mount set-up. That one's another story as well if I accelerate real quick on something like a 1/2 tank. Lights may drop two full lights then come back up after the bike settles back down to crusing speed. That one is more of a warning for me to check the fuel guage/indicators on the speedo if anything or at least that is how I view it.
Old Jul 30, 2012 | 08:26 PM
  #7773
iamawakenowtvm's Avatar
iamawakenowtvm
Default Thermo
When it gets wet is like stopping on ice...Also, if you find yourself in a hard braking situation and that is in your path, the rear wheel can lock up on you instantly...You may not be able to avoid them, but be aware that it is an instant trip to the pavement if you are not careful...
Old Jul 30, 2012 | 08:33 PM
  #7774
iamawakenowtvm
Default Fuel gauge
Do you regret buying the LED cap now, or is the "look" worth the money?...I REALLY like the way that looks...
Old Jul 30, 2012 | 08:58 PM
  #7775
Misbehaven's Avatar
Misbehaven
More or less bought my cap because it matched the other one. Had there been an option for one without the gauge I would have gone that route. But the blue lights are cool.
Old Jul 30, 2012 | 09:30 PM
  #7776
Jim_bo's Avatar
Jim_bo
Does anyone have a set of "fangs" that have been PC'd flat black? If so, can you post pics? I have a FB Lo with a windshield. I'd like to install the fangs for air management, but I'd really like to see what they would look like on my bike.
Old Jul 30, 2012 | 09:58 PM
  #7777
TNB's Avatar
TNB
No, I don't regret the purchase and I like the flush look of both the replacement gauge and fuel cap. The black goes well with my tank and the blue LED goes well with the colors I have set up for the speedo. To me, it's no different than buying some bling which has no real function.
Old Jul 30, 2012 | 10:10 PM
  #7778
chops103's Avatar
chops103
3rd Gear
here are some pics of my lo Name:  IMG_0188.jpg
Size:  158.7 KBName:  IMG_0184.jpg
Old Jul 31, 2012 | 12:38 AM
  #7779
Lightafatty's Avatar
Lightafatty
Originally Posted by Lone wolf lo 10
Does anyone know if the front fender off a fls slim fit on a Lo, I love the look of a bobber style fender and being able to order it already painted is just a plus
I've been wondering myself. It has the same front end, so the only issue would be the tire rubbing. I might just bite the bullet and give it a try. I think it would look killer on my Lo.
Old Jul 31, 2012 | 12:50 AM
  #7780
RightOnFatty's Avatar
RightOnFatty
Another factor that is MUCH more important to know is NEVER ride the center line for extended periods due to "fluids" build up...Every vehicle traveling that lane that leaks a oil based fluid leaks it in that "track"...They do not evaporate, so over time you have a very dangerous build up on some roads...You can usually "see" it as a very dark patch that almost looks like fresh pavement...The heat of the summer only compounds the problem.
Are you describing what was happening to me the other day? You must be there looking at me riding from behind or some thing. Just barely moving from left to right in within a street lane, I had to hit the brake slightly to reduce some speed, and as my bike passing through the 'dark patch' in the middle of the lane, its tail started to wag from side to side! It scared the s**t out of me. I wasn't riding faster than 40 mph and the sky was bright, in the mid day at around 90F warm.
