Ape hanger advice
Old Apr 23, 2010 | 01:54 PM
rowdy82's Avatar
rowdy82
Default Ape hanger advice
I have 16" gimps to put on my Crossbones. My question is if i run shorter risers (2" instead of 4") will i have enough cables and wiring without switching them out. By looking at them i think it would be close but im not sure. Thanks ahead of time
Old Apr 23, 2010 | 01:58 PM
hspring03's Avatar
hspring03
Not at all likely......
Old Apr 23, 2010 | 02:02 PM
brettnbama's Avatar
brettnbama
I don't know, but when you get it done, I'd like to see pics, especially with you sitting on it, like to see what the riding position is like
Old Apr 23, 2010 | 03:51 PM
jed1069's Avatar
jed1069
How tall are the original bars on a bones? if they are 10" plus your 4" risers =14" total and 2" + 16" = 18" diff of 4 " do your cables look like they have 4" of slack? Take off the clutch assembly and hold it up to where you think the new bars would be. My guess is they wont be long enough. But try what I just said for a better idea. I think where you will run into trouble is the internal wires will not be long enough they keep those pretty snug.
Old Apr 23, 2010 | 04:13 PM
BioMek's Avatar
BioMek
My guess would be no. Lenght-wise running straight up to the hand controls yes but if you want to keep a cleaner install and run your cables along the contour of your bars i'd say you'd most likely need a new set up but it also depends on the gimps pullback dimensions.
Old Apr 23, 2010 | 08:14 PM
rowdy82's Avatar
rowdy82
Yeah got home and took some measurements. Risers are just under 3" not 4" so no way this would work. Thanks for the help though.
Old Apr 24, 2010 | 12:18 AM
jumporjerkoff's Avatar
jumporjerkoff
i have just put 14" nash grits on with a 1" riser........was tight to say the least....
rowdyj
Jun 12, 2014 07:45 AM
ghoticov
Mar 8, 2013 04:45 AM
j88j
Oct 19, 2010 06:28 PM
bubba626
Apr 12, 2010 03:09 PM
Smokey Burnouts
Oct 11, 2009 10:31 AM
