New bars and bleeding brake
Old Apr 24, 2010 | 03:05 PM
zworld's Avatar
zworld
Default New bars and bleeding brake
Just got my drag bars on and all went well. Just haven't got the brake line bled, I had to put on a new line! Anyway a buddy told me to leave the cap off and all the bubbles will rise overnite. I have pumped it up and seen some bubbles, but will this work over nite?
Old Apr 24, 2010 | 03:11 PM
Arv's Avatar
Arv
Personally I dont feel thats enough.
The brake line needs bleeding, to make sure that brake works properly when you need it to.
Dont cut corners with your brakes..
Old Apr 24, 2010 | 03:23 PM
drjones's Avatar
drjones
It helps to have the fluid resivoir facing slightly down, lower than the handle. That will allow the air to rise into the master cylinder. If the handle is lower than the master cylinder, air will be trapped at the banjo bolt / brake line junction. Good luck. TJ
Old Apr 24, 2010 | 03:28 PM
Wild-deuce's Avatar
Wild-deuce
Its a hassle and half bleeding brake lines unless you have the right tool. I hated those long periods of time wasted trying to bleed them. I gave up and bought this tool which is a kick *** tool. Works excellent. In just a few minutes its done..
http://www.debrix.com/ProductDetails...tCode=57909-M1
I rarely use it, but its there when I want it..You won't be able to use it this time, but think about the next time...
Old Apr 24, 2010 | 03:53 PM
Willie D's Avatar
Willie D
Cool break bleed
we use a really slick vacum system . . . . work great.
JMHO
Old Apr 24, 2010 | 03:56 PM
zworld's Avatar
zworld
This sucks, I want to ride. I really hate to have to go buy a beeding system. I'm going to try the old fashion way when my son gets home.
Old Apr 24, 2010 | 08:11 PM
JimStro16's Avatar
JimStro16
Bleeding brakes shouldnt require any special tools. I have never had to use anything other than a wrench before. As long as there arent any leaks and the air is out, they should work.
I have never tried waiting til the next day and they will bleed themself. Never heard of that method before. The only way I know of is the old pump pump hold.
Old Apr 24, 2010 | 10:18 PM
myfhfb06's Avatar
myfhfb06
I bled my brakes the old fashioned way. Took about an hour to get it done but finally got it to work.
Old Apr 24, 2010 | 10:20 PM
zworld's Avatar
zworld
Woo hoo, got them bled finaly. Just kept trying finaly got it done, just got back from my test ride with new bars. love them, and the look.
Old Apr 25, 2010 | 09:02 AM
hksigman's Avatar
hksigman
