Hold in the odometer button while turning the bike on and off 3 times. Make sure the kill switch is set to on. Use the odo button to scroll through and find the code. Post the code here and we will help you out.
once you get the psspt you need to scroll through eac section using the odometer button to find the code. each letter represents a part of the engine. read this thread. https://www.hdforums.com/forum/dyna-...lear-them.html
P1353 is a combustion code. Plug wires my be switched, bad spark plug, bad connection, ect. Does it run? If so, sound like a$$? Hope this sends you in the right direction.
