91' Heritage Softail Spitting Oil
Old Aug 14, 2006 | 02:28 AM
harley198's Avatar
harley198
1st Gear
Default 91' Heritage Softail Spitting Oil
I have a 91' Heritage Softail that was running fine, but now when I go to start it, oil gushes out of the air cleaner, through that vent/oil hose. Why is it doing that? and what do I need to do to fix it? Any help would be appreciated. Thanks.
Old Aug 14, 2006 | 11:58 AM
Hossman's Avatar
Hossman
Default RE: 91' Heritage Softail Spitting Oil
I just had the same issue on my 1991 FLSTC
Shovelhead Bob said it might be
Head breathers are puking it out......
Others thought maybe to much oil in my tank.
Check out the tread here:
https://www.hdforums.com/m_677874/tm.htm
Old Aug 14, 2006 | 01:35 PM
dert's Avatar
dert
Sounds like the check ball is stuck .If is sits for a "long time" .it will do this .The check ball is the big " screw looking plug" just behind the tappet valve screen which looks the same.on the right side of the motor.You will see these close to the oil pressure switch.
tlrm13
Engine Mechanical Topics
Apr 13, 2017 08:38 PM
vb1340
Oil Archive (no new posts)
Jun 26, 2011 01:44 AM
coorsbig8balls
Mar 20, 2011 09:57 PM
ironoxide
Jun 30, 2009 11:37 PM
harley198
Aug 15, 2006 03:51 PM
