jetting or sumping?
Old May 8, 2010 | 09:15 AM
o/d's Avatar
o/d
Default jetting or sumping?
i recently did cam chain tensioners & andrews tw26a cams.
not really sure, but i think it may be slower than before. it doesn't run terrible, i'm just not real impressed.
i'm thinking of pulling the check bolt to see if i have more than 6 ozs. of oil @ the bottom, although i've read this is a risky task.
are there any other symptoms of sumping other than a loss of power?
i've done about 300 miles since the new cams & tensioners. would it have seezed by now if it was sumping?
would i be seeing blow by out the air filter?
regarding jetting - i have the stock pilot, 180 main, needle in 4th slot from top, and a harley jet kit(forget which one thunder slide, thunderjet??)
any jetting advice?
i was going to go to a 48 pilot & maybe try a 185 or 190 main.
Old May 8, 2010 | 11:20 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Did you replace all the bearing while you were in there?
Old May 9, 2010 | 06:34 AM
o/d's Avatar
o/d
i only replaced inner & outer cam bearings.
edit: 5/17/10
thought i'd edit this for anyone searching the topic in the future.
went from a 180 main jet to a 190 & it runs real good. definitely not sumping & i'm happy with the cams.
pegskraper
Jul 19, 2016 04:01 PM
sskimber
Engine Mechanical Topics
Nov 5, 2014 02:59 PM
natural gasser
Exhaust System Topics
Jul 20, 2012 12:28 PM
Larry64
Jul 27, 2011 10:04 AM
abigweasel
Nov 10, 2010 02:20 PM
