Brake Kleen question
Old May 21, 2010 | 01:23 PM
FrankT's Avatar
FrankT
Default Brake Kleen question
Getting ready to do oil change and wanted to know if using Brake Kleen (red can) will harm the powder coating or frame paint. Was planning on using this to clean up any oil that I spill especially when removing the filter. I have read mixed reviews on this topic. Any advice is helpful. Thanks.
Old May 21, 2010 | 02:47 PM
Bowtieman31's Avatar
Bowtieman31
I've found a little cleaning solvent and a soft brush is best, followed by a rinse of water. No harm to the paint or powdwer coating.
Old May 21, 2010 | 05:58 PM
scubadnv's Avatar
scubadnv
I use Simple Green full strength, it's safer and works very well for removing residual oil. I have found that any solvent cleaners can dull powder coat and wrinkle paint and even remove regular paint so I try not to use them as much as possible.
Old May 21, 2010 | 06:16 PM
Dorkman's Avatar
Dorkman
Don't have a can of Brake Kleen around, but check the label. Most will have a warning to keep it off the paint, if necessary. A rag and paper towels works as well...
Old May 21, 2010 | 09:16 PM
Other Sheep's Avatar
Other Sheep
I've used some brand of Brake Parts Cleaner on my two harleys after every oil change. I don't care how careful I am, what various objects I use, how much oil I try to get out of the filter before removing, I make a mess every time. I've just learned to accept it and clean it with my brake parts cleaner. Never affected the engine paint on my 99 after 40,000 miles and hasn't done anything to my 07 after 27,000 miles.
Old May 21, 2010 | 11:54 PM
BLKBAGGER's Avatar
BLKBAGGER
I use brake clean to blow off the little bit of oil spilled after an oil change. I haven't noticed any dulling of the powder coat. Just a little warning though. If you are a smoker don't use the red can and smoke around it. it can kill you. The green can is non chlorinated and much safer.
Old May 22, 2010 | 12:07 AM
Wanna Ride's Avatar
Wanna Ride
Agreed. Simple Green is good stuff. Just don't let it evaporate or dry on sensitive surfaces. Let it sit and do it's thing for a little bit, then rinse thoroughly with the water hose.
JKSHYT
Powdercoat & Paint
Dec 31, 2016 04:01 PM
cmosentine
Powdercoat & Paint
Jul 17, 2012 10:32 AM
OldNavy66
Powdercoat & Paint
Sep 10, 2011 10:26 AM
iDodgimus
Mar 30, 2011 02:41 PM
quin
Aug 24, 2008 03:28 PM
