Help with heritage
Old May 21, 2010 | 05:47 PM
oldryder's Avatar
oldryder
6th Gear
Default Help with heritage
Newbe to this forum. My bikes are a dyna and ironhead. So I don't come here much. A friends husband passed away about 6 months ago and left her a 99 heritage. It had been sitting before that. My understanding is that it was running before he let it sit. What do I need to do before bringing back to life. I was thinking about squirting wd-40 in the cylinders and turning it over with no plugs to get the oil moving. Drain the gas in the tank and carb and fill with new. She has a new battery so that should be alright. Any help, suggestions would be appreciated. Thanks
Old May 21, 2010 | 05:50 PM
bear68's Avatar
bear68
Instead of WD-40 I would recommend automobile ATF (trans fluid) I use it with car engines that have been sitting a while or have carbon buildup in the cylinders. Gives a reasonable amount of lube while cleaning at the same time. Once you get it running for a few hours, change the oil.
Old May 22, 2010 | 12:31 AM
Bluehighways's Avatar
Bluehighways
+1 on the ATF, otherwise it sounds like you're on the right track. After a couple hundred miles I'd change the oil in all three holes again.
Also change the fork oil.
Watch for leaks. The nemisis of a sitting machines is that seals can take a set, bearings and gears that haven't been covered with oil for a long time can get a fine coating of rust on them . . . there's not much you can do but watch, change the fluids a couple of times in a row and then keep your fingers crossed. Usually things will turn out just fine. But a bit of paranoia doesn't hurt.
ChromeJunkie
Mar 8, 2016 08:28 PM
liljay1982
Aug 7, 2012 04:15 PM
campdreamer47
Apr 11, 2012 06:52 AM
aquaelvis
Oct 20, 2011 01:13 AM
bobbyd3
Mar 20, 2010 10:13 PM
