Part # needed
Old May 23, 2010 | 05:02 PM
aviscomi's Avatar
aviscomi
Default Part # needed
My saga continues...I got the acorn nut off the console; actually I just ripped the entire console off the tank (too much coffee). Now I need to know the part# for the bracket that the console mounted to. Its the bracket that has 10 torx screws and I assume its holds the fuel pump. My bike is a 2008 Nightrain.
Old May 23, 2010 | 05:50 PM
Rockyriver's Avatar
Rockyriver
For some reason my parts catalog does not show the top plate listed as an indivivual item, it shows the entire assembly of fuel pump, and sending unit. THE entire assembly is called "Module assembly". Sorry Im no help here.
Old May 23, 2010 | 07:45 PM
aviscomi's Avatar
aviscomi
Thanks for looking...I will be pissed if Harley doesn't sell it seperatly.
Old May 23, 2010 | 08:01 PM
Rockyriver's Avatar
Rockyriver
Look at this picture below this is the only layout I got. It does not show a place for the stove bolt to mount to either. Maybe this is the wrong one?
There should be a bracket for that bolt that holds the console on shown ?
I beleive this to be a 2007 manual, this could be the problem.
Old May 24, 2010 | 01:58 AM
kiwideuce's Avatar
kiwideuce
aviscomi,thats a good lookin softie in your sig!
Old May 24, 2010 | 05:19 AM
Rakthi's Avatar
Rakthi
Here is a scan from the 2009 parts catalog,
14 is part number for the FXSTB is 75211-08 TOP PLATE ASSEMBLY and comes with part number 61381-02 which is the gasket (number 9 in drawing) that the service manual says you have to replace anyway.
I would also buy the 10 screws (number 1 in drawing) which you are supposed to replace as wel.
Partnumber 1311D - SCREW (10)
75211-08 will set you back $41.70 at dealer
1311D will run $1.00 x 10 = $ 10.00 at dealer
Hope this helps.
Old May 25, 2010 | 01:56 AM
tk353's Avatar
tk353
maybe you should try fixing it
Old May 25, 2010 | 12:28 PM
aviscomi's Avatar
aviscomi
Yeah, I'm sure that I could "rig" something up in order to get the console mounted again.
Crashrdking01
Aug 21, 2018 08:33 PM
rtreftz
Sep 25, 2016 12:39 PM
trakfloater07
Jun 11, 2012 10:33 PM
bagman1
EVO
May 25, 2011 10:03 AM
live4rut
Sep 18, 2010 09:00 PM
