Opinions on these Dyno Numbers
Old Jun 8, 2010 | 11:19 AM
  #41
XARAN's Avatar
XARAN
Originally Posted by shineybike
New numbers:
76.85 hp 92.20 tq
That's more what I was expecting from what I've seen on the forum of other similar builds. I'm sure I could do even better with a good 2 into 1 exhaust, but for now I'll stick with the true duals. The builder was great about this. No cost to me for the fix or re-tune. I'll be picking it up tomorrow. I got a faxed copy of the dyno sheet but it is in mph instead of rpm's. I'm gonna get a reprint in rpm's and will post.
Now thats much more like it. Those are good numbers for your set up. You will still gain from a 2 into 1 pipe but at 92 tq you are doing pretty darn good with stock heads.
Have you ridden it , its got to feel like a different bike now!
Old Jun 8, 2010 | 01:03 PM
  #42
matt816's Avatar
matt816
Sorry didnt read the whole thread... what was done with your heads?? if nothing then your comrpession isnt that high. that setup with flat tops would be somewhere between 8.9 and 9. Thats pretty low to build power. Headwork needs to be adressed ASAP, and definitely a differant pipe setup. my 95" with SS 570s and custom headwork at 9.8 with a pro pipe made 99 hp 104 tq.
Old Jun 8, 2010 | 10:05 PM
  #43
fat15th's Avatar
fat15th
Your air to fuel mixture is way off . Look at the red line fall on its face at around 3500, right where everything else does. The red and blue lines should be togther as close as possible, you might be running really rich. example; look at hspring03 dyno sheets
Old Jun 8, 2010 | 10:58 PM
  #44
nikonf8's Avatar
nikonf8
Default motor
i did not see you list any head work without doing the heads i would not expect any more. i believe the heads would make a big difference
Old Jun 9, 2010 | 07:01 AM
  #45
shineybike's Avatar
shineybike
Thanks for the feedback. No head work has been done. Maybe some time in the future. I will be picking up the bike today and looking forward to feeling the difference.
floridamk
Exhaust System Topics
Apr 29, 2013 08:12 PM
coronerrpm
Jul 28, 2010 09:08 AM
mhud
Jul 5, 2009 03:02 PM
anubisss
Jun 29, 2009 01:07 PM
bob2002
Dec 13, 2007 12:42 PM
