Switching to chrome switches
Maybe would be good to start an area where people explain thier mods ??
Thanks
Here's the pics
http://i110.photobucket.com/albums/n...orcycle012.jpg
http://i110.photobucket.com/albums/n...orcycle014.jpg
Did you powder coat the handlebars.
Denis
Denis
What do ya think?
Denis
What do ya think?
I think your bike is a great color. If you go with black bars, the more black you can tie in, i.e. the wheels, frame, etc, the better it will come together. I think you may also want to consider the front end parts black as well (forks, upper and lower, lights, etc). Maybe before you go too far, ask one of the talented folks in the photoshop forum to take a stab at blacking out some parts for you on a pic of your bike. That's what I did, and it helped me a lot!
Here's what they came up with:
although the blacked items are plentyful, I am not sure I am totally going this route.
Give them an idea of what you are looking to do, I'm sure they'll help you out!
What ever way you go, I'm sure it will look awesome!
Post pics, or PM me a link to the pics that they post for you. I am curious what they come up with!!!!!
1. \\; .I normally start on the throttle side. \\; Loosen the throttle cable adjusters to have enough slack to remove the throttle cables from the grip. \\;
2⌠\\; Remove the two screws that hold the switch housing together.
3âŚ. Separate the switch housing and remove the screw in the upper housing that hold the switches in place. \\; Then the switches should come out of the housing.
4âŚ. \\; Carefully using a small screwdriver or a pick. \\; Pry the caps off the switches. \\;
5âŚ. \\; Next just snap the appropriate switches back into place.
6âŚ. \\; Reinstall in reverse order.
7âŚ. \\; Now for the bottom half. \\; You will have to remove the throttle cables from the grip. \\; Since you have already taken the slack out of the adjusters, \\; they should already be loose enough to remove. \\; Just make sure you donât loose those little brass barrel thingys that are on the ends of the cables. \\;
8⌠\\; \\; Next remove the screw in the lower housing that holds the switch in place and then the switch will come out of the housing.
9âŚ. \\; Pry the switch cap off, \\; \\; then install new switch, \\; Replace entire switch back into housing and replace screw.
10. \\; \\; \\; Reassemble both the throttle lines in the grip and now put both halves of the switch housings back together and tighten up.
11. \\; \\; \\; Adjust the throttle cables per service manual instructions. \\; \\;
12. \\; \\; \\; Then you are done with the first side, \\; The other side is the same just no throttle cables to worry about.
I thought it was pretty easy. Did pretty much what everyone has already mentioned. I believe it took about 40min.
Very helpful thread also.
yes, thank you jcboof....I got the left side finished with no problems but started on the right side and the directions that came with the switches really do suck.
