have always had a problem w/ cheap chrome on harleys here in the northeast. while redoing my bike this winter i bought a complete kit of stainless bolts from ALLOY BOLTZ in FLA. everything worked great, just follow they're torque spec and they tell you to use blue or red loctite or anti seize on every bolt. watch your torque carefully on the small screws, i stripped the head on one of the derby screws because i did'nt hae a inch pound torque wrench. This company ihas very good customer service, as i was runnin a different front rotor the washers they sent were too big, she shipped out two different size washers next day n/c.
Let me make sure I understand you - first you replace, then you polish?
Also - which specific HF buffer?
Item # 94393 listed under bench buffer grinders
I use this particular one because it has two buffing wheels so you can use one color rouge on one wheel and another on the other wheel which makes for a quicker job. I buff the screws/bolts using holding jiggs I fabricated from anything I could find which would hold screws safely but you can use ViceGrips if that is all you have. The web site admiretheshine.com has very good buffing wheels if you want to get pretty serious about buffing and the wheels he sells make the job faster (about 1 minute per bolt. OH yeah I buff them before installing them. You will be supprised how many thing you will buff if you have this equipment.
I think this is probably the best route. I thought I could just run down to the local ACE whenever I had a tinkering itch, but they aren't polished. I could go the buffer route, but at that point its getting more complicated than I was looking for, so Alloy Boltz it will likely be...
I used a threaded coupling and a nut to hold and lock mine in place while I buffed it. A threaded coupling is used to hold 2 peices of threaded rod together for like when you are hanging air pipe from the ceiling in industrial applications. Three sizes are about all you need.....1/4 20.....5/16 18.....3/8 16.
Lacking that, a friend of mine has a micropolishing business on the side he's done for 40 years - he just puts on cotton gloves and goes at it, on those big 12" buffing wheels. I like the coupling idea better tho...it's easy to slip and turn a bolt into a bullet.
