Deuce headlight bucket swap
Old Aug 19, 2006 | 09:50 AM
Jezcruzen's Avatar
Jezcruzen
Default Deuce headlight bucket swap
My Tradewinds bucket (5 3/4" Concours) arrived yesterday, along with the Headwinds mount listed for FXSTD application.
Upon examining the mount (which is sort'a "L" shaped to allow for some extension out from the triple tree) I couldn't help but notice that the 3/8" hole that would be used to attach the mount to the top of the bottom triple tree was not drilled in the bottom of the mount, but was drilled in the side of the mount instead! There's no way this thing mounts as I would expect it to to the top of the lower triple tree where the stock headlight mount attaches.
Is this a mistake from the manufactureer of the mount, or am I just not seeing the obvious? The pittiful instructions included seem to indicate that the attachment hole is in the bottom of the mount, not in the side like mine is.
Any help or advise appreciated.
Old Aug 19, 2006 | 03:09 PM
Jezcruzen's Avatar
Jezcruzen
Default RE: Deuce headlight bucket swap
bump
Old Aug 19, 2006 | 03:14 PM
voodoo93's Avatar
voodoo93
Jez,
That mount must be the wrong one - you should have an L (or weak J) shaped bracket with a hole in the side the short leg bends twoards - the bracket definitely mounts from the bottom and bends down towards the tire. If I am not clear let me know and I will go snap a pic and post it.
Old Aug 20, 2006 | 12:07 PM
Jezcruzen's Avatar
Jezcruzen
ORIGINAL: voodoo93
Jez,
Well...maybe I 've been looking at this thing all wrong! If the leg that the light bucket mounts to turns down towards the tire, then maybe this IS the correct mounting block. (1-0012CA, Mount, Rocket, FXSTD, CHR PL) Its Headwinds # 626-359-8044.
So, you're saying that the leg having the mounting hole drilled in the side attaches to the triple tree and the leg containing the drilled (and tapped) hole all the way through hangs off the front of the triple tree, turned down towards the tire. I just didn't consider this because I assumed that the bucket wouldn't have enough clearence. I guess I had a preconception as to how the mount was supposed to go.
I'm going out and check this out! Thanks VooDoo.
Old Aug 20, 2006 | 12:39 PM
Jezcruzen's Avatar
Jezcruzen
Repeat after me...Les, you're a dummy, Les, you're a dummy...
Yes, the mount does work! I'm sooo excited!
That is the danger of sticking to preconceived notions. I had it in my head that the mount attached a different way.
Thanks, VooDoo. Information swapping like this (and the people who hang around here) is what makes this such a great resource.
Now, I'm going out and install that new bucket!
Old Aug 21, 2006 | 12:29 AM
voodoo93's Avatar
voodoo93
Glad to be of help - your right about the value of this forum! Let's see some post install pics.
RPG485
Jan 15, 2014 10:07 PM
godjunior
Jul 10, 2012 04:17 PM
motordrum
Nov 30, 2008 09:50 AM
drumer66
Feb 21, 2008 08:17 PM
Sabaka454
Jun 21, 2007 11:35 PM
