Blue Job Polish Ruined my Exhaust Shield
I apply this Polish to my heat shield and for a few minutes its taking the gouge out! Im getting pretty excited and decide to take a break. I come back to it and the Polish has turned part of my Shield to an orangy tinge. The scratch is gone and now I have this orangish discoloration on my heat shield. WTF? I was rubbing it in a paste form as the directions state for only about 5 minutes or so. Did I go through the chrome? WTF? Now im looking at about 150 bucks to replace the stock heat shield
If the scratch was something you did, offer to buy one of the used take offs if they get one in the future. I had a friend buy some sportster mid control take offs from the dealer for like 20 bones. If the customer doesn't want them, they usually just chuck em (depending on the dealer).
Good luck!
I said well Harley wants to charge me the better part of $200 Canadian for something you just throw in the garbage? Unreal, they are currently trying to help me out.
Also, I was the one who put the gouge in my Shield. I figure it was when I was doing a Uturn on a gravel road one time, got a rock stuck in my boot tread and hit the pipe with it trying to find the footboard.
From their site, concerning a set of pipes that were thoroughly blued and trashed:
#5 These pipes did have a couple of heavy scratches and a dent or two, that could not be fixed, oh well...
"Heavy scratches" aren't gonna get removed.
FWIW, chrome, or good chrome, is often seen as "triple chrome plating", but isn't 3 layers of chrome. After the metal is polished and cleaned, it is dipped into a vat where a copper coating is laid on, then cleaned, then into a vat where nickel is laid on, then cleaned, and then into a vat where the thin layer of chrome is laid on. The quality of the polishing is the most important part of the process, in my opinion. Of course, cleanliness is of great importance in the process, too. The copper provides a surface that allows the nickel to stick. The nickel provides the depth and luster of the final product. The chrome provides the "flash"!
Here's a pic of my timing cover where I purposely polished through the chrome and nickel to expose the copper. I painted the entire cover in Rustoleum Hammered Black, then sanded the cross with 240, 320, 400, 600, 1000 grit. Next I used a 3M Scotch Brite pad to provide a directional satin finish to the cross, and finally shot a clear coat to prevent any further oxidation. The clear coat product was purposely incompatible with the Hammered Black so it would "wrinkle" it.
The stock pipes? throw 'em out and get a set of pipes you like with some growl to them. Tell them to give you a good discount on a aftermarket set of pipes... then you both win...
