Tranny oil !
Old Jun 14, 2010 | 02:37 PM
DaSham58's Avatar
DaSham58
Default Tranny oil !
I just serviced my 09 Heritage and I switched the weight in the tranny from Amsoil Severe Gear 75W-90 to Amsoil Severe Gear 75W-140 and all I can say is wow I mean double wow what a big difference it has made in the shifting and I even noticed how much more smoother it goes down the road! There is no more clunking when changing gears . I also switched oil filters from k&n to this one . Never should have to buy another oil filter !
Tranny oil !-0712-0219.jpg http://www.powersportsuperstore.com/...-0093&CartID=1
Old Jun 14, 2010 | 07:03 PM
Schaub85's Avatar
Schaub85
think I'm gonna have to do this, mines clunking more now that I put the mobile 1 75-90. thanks for the info...
Old Jun 14, 2010 | 07:11 PM
twistr's Avatar
twistr
Yup...Amsoil Severe Gear oil is good stuff...I am an authorized dealer and...no I am not bias..it works great
Old Jun 15, 2010 | 10:52 AM
DaSham58's Avatar
DaSham58
I couldn't believe the difference between the 90 and 140 has made it is shifting so much better now ! Life is good again .
Old Jun 15, 2010 | 12:03 PM
nemick's Avatar
nemick
I've been using the RedLine Shock Proof Heavy and been pleased with it. I'll try the Amsoil next and see if there is a difference.
Old Jun 15, 2010 | 12:12 PM
DaSham58's Avatar
DaSham58
I have used the RedLine Shock Proof and this 75/140 Amsoil so far is the best I have used .
Old Jun 15, 2010 | 12:35 PM
04Springer's Avatar
04Springer
This could not have com up at a better time. I am looking at changing all 3 oils for the first time myself(engine, primary, and tranny).
I called the dealer today just to get some info (first mistake right?) on the oil types I should use. I have been running synthetic since new. I wanted to know if there is any difference between the 3 oils, or is it the same oil across the board. Basically, is there primary oil, which is different from engine oil, etc etc. He said for synthetic...there is NO difference. But I just couldnt imagine running 75-140 in the engine and primary. My shift clunking is bad, so I will try this Amsoil Gear oil, but to me it shouldnt be used for engine and primary right? And if so, what Amsoil (or other brand) would you recommend?
Sorry to taker it slightly off topic there....
Old Jun 15, 2010 | 01:44 PM
DaSham58's Avatar
DaSham58
I use amsoil in all 3 holes I use 20w/50 in the crankcase and just switched to the Severe Gear 75W/140 for the tranny and 10W/40 Advanced Synthetic Motorcycle Oil in the primary ,
Old Jun 15, 2010 | 01:57 PM
Sagexpman's Avatar
Sagexpman
Is that an Amsoil filter?
Old Jun 15, 2010 | 02:03 PM
DaSham58's Avatar
DaSham58
No it is a PC Racing Stainless Steel filter.
http://pcracingusa.com/store/product...roducts_id=169
