1988 FXSTC electrical problem
Old Jun 14, 2010 | 10:38 PM
redemption denied's Avatar
redemption denied
2nd Gear
Default 1988 FXSTC electrical problem
i put a new ignition switch on and i turn it to the igniton position and the oil light comes on but wont start i turn it to the lights position and the lights came on then i pushed the start button and the lights turned off and the starter relay clicked once and thats it the lights wouldnt come back nor would the bike start
does anyone have any idea what it could be i cant seem to figure this out
Old Jun 15, 2010 | 04:36 AM
Tom84FXST's Avatar
Tom84FXST
Some of the aftermarket switches are different than the factory ones, as far as what wires go on what terminals...so if you can't use a meter you are SOL. Where did you get you replace switch?
Old Jun 15, 2010 | 06:22 AM
texas-buzzard's Avatar
texas-buzzard
the switch is either the wrong one or it is wired wrong. check the wireing diagram in the service manual.
Old Jun 15, 2010 | 06:43 AM
jaqmes's Avatar
jaqmes
loose wire or dead batt? without more info hard to say.
Old Jun 15, 2010 | 09:12 PM
redemption denied
2nd Gear
i got the switch from j&p cycles in daytona its the same one and i used the manual and all the wires are connected correctly also the battery is only one month old its a dry cell from harley
Old Jun 16, 2010 | 10:11 AM
Bingee's Avatar
Bingee
I have an '88 fxstc. Had an after market ignition switch that lasted a few months. It was junk. I went with a genuine HD switch and it's lasted 10 years so far. So it could be the switch. Not highly likely. But possible. You need a meter to check it out. They have them at Lowes for cheap price. You say all the wires are connected correctly. Well, maybe not. Try rewiring it again after checking out your switch. Also look for hidden breaks within in the wire insulation. They're old and can get brittle from the elements. I had that happen and it was hard to detect. Did you check all fuses? This why a meter helps. One other thing. Check out the kill switch. Those old ones are a little flaky and sometimes don't make contact. Good luck.
Old Jun 16, 2010 | 05:54 PM
Tom84FXST's Avatar
Tom84FXST
J&P sells 2 switches...one is a Harley knock off that will work exactly like the Harley one. They also sell what they call an "electronic" switch...the poles are not in the same place as a stock switch and if my memory still works, it seems I even had to use a jumper to make it work. You can tell by looking at the back of the switch...if you can't see the bar and contacts...you have the electronic one
Old Jun 18, 2010 | 06:05 PM
redemption denied
2nd Gear
i have the one with the bar and contacts that you can see its exactly the same as the old one and the wires are on exactly how they were on the old one and same as what the manual said
the manual also said that from the starter relay the ground goes to the rear fork bumper stud and i dont see where the ground wire goes other than back into the wiring harness
Old Jun 27, 2010 | 02:40 PM
redemption denied
2nd Gear
im just pointing out that you have the same bike as me and you told me to check the fuses when the bike doesn't have fuses it has circuit breakers. the ignition switch i just replaced was the original one from 1988 also including the wiring problems are coming from the connectors between the tanks
Old Jul 8, 2010 | 01:02 AM
redemption denied
2nd Gear
ok so i tested all the wires on the ignition they have no resistance in them i can get the head light to turn on but when i push that start button i can hear the starter click once and then all the power goes away then you can see all the lights slowly get brighter and brighter till its all the way on then you can push the start button and you hear the starter click once then does the whole process over again
i was told maybe it was the starter but wouldnt i be able to push start the bike if it was the starter becuase i try'd push starting it and i got nothing
hell hound
Shovelhead
Jun 13, 2019 09:19 AM
Poa
Electrical/Lighting/Alarm
22
Mar 7, 2019 10:09 AM
Stranger
May 16, 2012 08:53 PM
Staggerty
Jul 8, 2011 12:24 PM
52edub
Nov 10, 2007 04:35 PM
