Radius Pipes - V&H vs. Freedom Performance
I just got my Fatboy and my first mod will be to replace the exhaust.
I want some sort of "radius" pipe. I saw two that look almost identical and wanted to know if there are any differences in performance and/or sound.
The Vance & Hines Big Radius
vs.
Freedom Performance Sharp Radius
Comments very much appreciated.
vs.
VH are more expensive but look better; chrome is thicker looking. VH BR will bring better numbers on a Dyno as well. Although they are more expensive, there all deals to be had out there. I think I paid just under $400 for mine a couple years ago. Used an indy who got a good price plus he took a few bucks more off because I throw a lot of money his way.
The Troublemakers were far less expensive (I think Hooker has discontinued them so you can find good deals with vendors trying to unload remaining inventory). My set ended up with some discoloration on one of the pipes fairly early on. I believe it was a combination of heat and my getting some oil on the pipe and not cleaning it off properly or right away. Still, the thinner chrome does not handle stains very well as might be expected with the VH. Form follows function on my bike so this was not a concern but it should be considered if you ride a show bike. Dyno results included decel popping resulting from reversion in rear pipe. Apparently the small difference in length between these and the VH BR makes a big difference in that regard as well as ground clearance which I will speak to in a second.
Both exhausts look good overall and sound pretty good. The VH BR are on a 96 and the Hookers are on an 88 so the VH sound a little meatier but the engine size has a lot to do with that. Cams in the 88 make the Hookers sound comparably bad a$$.
Is ground clearance an issue? That was the deciding factor for going with the Hookers on the Springer. Both bikes are lowered but Springer gets ridden much more aggressively; severe lean angles are common on twisties. Tips of Big Radius terminate a couple inches below the two rear exhaust bracket mount bolts. In contrast, the Hooker tips terminate just above the rear exhaust bracket mount bolts. That provides about 3" more ground clearance.
vs.
So, why do I recommend them after all that? Because the improvement in acceleration was that impressive! My indie has since sold other Freedom Performance exhausts (some with similar back order issues, but all the rest at least shipped with everything including hardware), and despite those issues, he still recommends them over Vance and Hines. This is partly because he
