A Couple Issues with my Heritage...
Old Jun 22, 2010 | 02:21 PM
03sporty's Avatar
03sporty
What I was told by a tech at my dealer, all they do is just a snug. He actually showed me on my bike when I first got it. A couple times I found a couple slightly loose. I too also had my steering bearings re-adjusted at about 3K. I had it in for a vibration, and they said it's a common problem. It helped.
Old Jun 22, 2010 | 02:51 PM
Mast1017's Avatar
Mast1017
Well, Shiney, it's certainly warm here in Texas - a little over 100 daily. As for the spokes, I will do my research onn the adjustments and if i don't feel confident doing it, than I will have a pro look at her. Again, thanks for all the insight and cautions, folks.
Old Jun 22, 2010 | 04:53 PM
k1768's Avatar
k1768
For me it's always been the fall away adjustment (neck bearings).
Old Jun 22, 2010 | 06:50 PM
Hockey Stick's Avatar
Hockey Stick
Excess grease is normal. Wipe it away.
Steering head bearing (or whatever it's called) being loose on the heritage is very common and causes a wobble on decelleration.
Old Jun 22, 2010 | 08:41 PM
Mast1017's Avatar
Mast1017
Well, I went around the wheels and snugged all the spokes like you suggested 03Sporty. Took the bike out on the road and the wobble is gone. Did the clutch-in-deceleration and the bike feels firm. The loose feeling in the rear end is gone, too. However, I still want to cover all bases and figure out this neck bearing or steering head bearing situation. If its common for the heritage to get a loose one of these, how do I tighten it and what are some good tips?
Old Jun 22, 2010 | 08:54 PM
Mast1017's Avatar
Mast1017
Nevermind, I just found another thread describing in great detail how to adjust the neck bearings. Thanks, again.
Old Jun 22, 2010 | 10:22 PM
Heritage632's Avatar
Heritage632
As I said, the grease is normal as it's happened to my bike several times (most likely after service as I have 20,000 miles on my 07). I'd leave the spokes to the techs, like someone mentioned, I don't think it's as easy as just going around the wheel and tightening. I'm telling you, I had the same symptoms....felt like I was on ice at slow speed and turns, high speed with hands off (not recommended of course LOL) it wobbled pretty bad. Mine was the rear and since the new wheel, it's been 15,000 miles and all is good. (I did have my steering tightened at my 1,000 miles service as well)
Steve
Old Jun 23, 2010 | 08:53 AM
Swilkins's Avatar
Swilkins
I am currently dealing with the same problem on my 07 Heritage and will finish the fall away test/adjustment tonight. Neck bearing was way below 70 to 75 lbs torque so hopefully now that I've torqued it back it will be fine.
Old Jun 23, 2010 | 09:21 AM
jimsflh's Avatar
jimsflh
Originally Posted by jimmers1817
I'd leave the spokes alone unless you know what you're doing. It's not as simple as going around the wheel and tightening spokes. You could end up creating problems rather than fixing them.
+1 good way to pull your rim out of true if you don't have an indicator (or a grease pencil with a tape jig at the minimum)
mbranscum
Oct 26, 2012 09:16 PM
RickV
14
Jul 19, 2011 10:46 AM
Jim Kraft
EVO
Jan 25, 2010 07:53 PM
buckwheat
Jul 11, 2009 11:52 PM
ronny c.
May 18, 2009 08:40 AM
