"Tricks" for removing 99 down softail shocks?
Old Jun 26, 2010 | 03:23 PM
JustDave71's Avatar
JustDave71
Default "Tricks" for removing 99 down softail shocks?
I have a floor jack, but when my bike is up on it it creates a hell of a time getting those shocks off. Jack supports get in the way of loosening mount bolts, and then shocks can't drop because of the jack, either.
what do the rest of you do to get access to your shocks and R/R them when you need to?
Old Jun 26, 2010 | 03:34 PM
pococj's Avatar
pococj
I have a couple home-made lifts that allow easy access. Here's a link:
http://www.nightrider.com/biketech/bikelift.htm
Old Jun 26, 2010 | 03:57 PM
JustDave71's Avatar
JustDave71
smart!
I was thinking of scoring some jack stands, as that would give the room I needed.
good on, man.
Old Jun 26, 2010 | 05:09 PM
Rockyriver's Avatar
Rockyriver
Heres a picture of my bike up on automotive jack stands. When I was replacing shocks I just took out the jack in the center. The jack under the rear tire made it easy to go up or down to line up the shocks (Strap the rear tire to the jack if you do this to prevent slippage off the jack on the tire).
Attached Thumbnails "Tricks" for removing 99 down softail shocks?-dscf0010.jpg   "Tricks" for removing 99 down softail shocks?-dscf0011.jpg
Old Jun 26, 2010 | 05:15 PM
JustDave71's Avatar
JustDave71
^^^exactly how I pictured doing it. Don't have jack stands. I know they're cheap.
I guess I didn't need to specify 99 down. pretty much the same for 00 up, isn';t it
so is that nice and stable with the bike on four jack stands like that?
Old Jun 26, 2010 | 09:57 PM
Rockyriver's Avatar
Rockyriver
I have an engine guard, and that makes for a great resting place for the jack stands right where it bolts to the frame. I used some 2X6 boards and 4x4 post nailed togeather under the front tire (see above picture again).
The only difference on a 99 and earlier and a 2000 and up on the shocks is the older models use two eye holes to bolt up the shocks and the newer models use one eye hole (at swingarm) and one stud bolt to mount up to the frame. But other than that they should be the same. If you use the same setup like mine in the pics it was very stable, just use common sense when breaking the bolts lose and maybe even have a friend hold the bike to help stabilize the bike for safety. When you go back with the bolts be sure too use blue loctite.
Skully
2014-2024 Touring Models
17
Apr 29, 2014 10:54 PM
jacknthebox
Apr 23, 2012 11:59 AM
hoethree
Apr 8, 2012 11:57 AM
jimmything
Nov 9, 2008 09:22 AM
Flying Pilgrim
May 2, 2006 04:29 PM
