Removing shocks
Old Nov 8, 2008 | 02:19 PM
jimmything's Avatar
jimmything
Default Removing shocks
I'm planning on taking my stock air shocks off my RK classic and have them shortened. Now, to get the shocks off, can I just jack the bike up and take the weight off the shocks (and any minimal air pressure in the shocks)and then un bolt them? I'm not a RUB, but I've never replaced shocks on a bike.
Old Nov 8, 2008 | 02:27 PM
greg09997's Avatar
greg09997
Jack the bike up and then put a 4x4 or something under the rear tire, lower the jack enough to make contact with the tire and you're set.
G-
Old Nov 8, 2008 | 02:29 PM
GT_RoadGlide's Avatar
GT_RoadGlide
Yes, jack the bike up. Use tie downs to keep it stable. Depending on the jack you should be able to get just enough elevation so the tire is just making contact, but no compression on the shocks. Be careful of the air lines.
Old Nov 8, 2008 | 02:56 PM
jimmything's Avatar
jimmything
Thanks dudes...
Old Nov 8, 2008 | 03:02 PM
jimmything's Avatar
jimmything
Thanks guys...
Old Nov 8, 2008 | 03:56 PM
EasternSP's Avatar
EasternSP
Yep, that's pretty much how ya do it. Replaced mine with Progressive 440s today. One of the stock shocks had blown a seal. If you look real close at the top of the shock where the air line connects, you will see a raised ring. Depress that and it will release the air line and the air from the entire system.
Old Nov 8, 2008 | 04:15 PM
Lincoln33's Avatar
Lincoln33
I made this change a while back and put a low profile jack (Compact car jack) under the rear tire so it was easier to raise the tire up when installing the shortened shocks.
Old Nov 9, 2008 | 05:01 AM
jcbpa's Avatar
jcbpa
now that you are changing them, give Howard a call at Motorcylcemetal.com This guy knows more about shocks than anyone I've ever talked too. He will have a set custom built for you. I have a set of brand new 440's used about a week that I'm going to sell, they are 13" though... nice ride, but not like my Penske.
Old Nov 9, 2008 | 09:22 AM
FLoTR's Avatar
FLoTR
If you're going to leave the bike on the jack while your shocks are modified, you may want to jack it up high enough to reach one of the locking points on the jack. It would really suck for that jack to leak down while you're gone.
robbyville
Mar 26, 2016 07:44 PM
Ozark Joe
EVO
Feb 16, 2016 08:26 AM
wichitaks
Apr 25, 2014 08:40 AM
jackinthebox
Sep 3, 2011 08:39 AM
JustDave71
Jun 26, 2010 09:57 PM
