lounder baffle
Old Jun 28, 2010 | 01:28 PM
Kojax's Avatar
Kojax
Cool lounder baffle
i have the fatboy lo with rush slip on 2 inch baffle looking for a lounder sound io checked big city baffle they have nothing that is easy need to take my slip on mufflers off i do not want to do that they are a pain to take off looking for some thing easy to replace, any company make them thanks
Old Jun 28, 2010 | 01:31 PM
sEEkEr's Avatar
sEEkEr
my 1.75 are slightly too quiet also....
Old Jun 28, 2010 | 01:33 PM
colonelangus1's Avatar
colonelangus1
to do any baffle work or mods on any muffler/slip on you HAVE to take them off .i just removed my SE baffles and drilled them out and chucked out the wading..once the bolts holding the baffles in are removed then its a matter of finding something to hammer them out with..i used a long screw driver and a ballpeen hammer and it took about 5 minutes each side ..the whole job took about an hour ..if you have stock cans they are riveted in..
Old Jun 28, 2010 | 05:03 PM
jimmers1817's Avatar
jimmers1817
Move up to a 2.25 or 2.50 baffle which are sold separately. Remove the screw on the bottom of the slipon and slide out the old baffle, insert the new. Piece of cake.
Can't imagine needing anything louder than 2.0s but to each his own.
Old Jun 29, 2010 | 12:34 PM
sEEkEr's Avatar
sEEkEr
Are you saying the longer the baffle the louder the pipes?
Old Jun 29, 2010 | 07:39 PM
jimmers1817
It's the girth not the length.
Old Jun 29, 2010 | 07:57 PM
sEEkEr's Avatar
sEEkEr
Aha...thanks for the clarification....
Old Jun 29, 2010 | 11:39 PM
oct1949's Avatar
oct1949
be prepared to loose some low end with bigger than the 2's... unless U have a BB kit with some cams..
They are now recomending 1 3/4 in stock form and 2'' with cams...
As said above, my two inchers will set off car alarms now,, I dont want any more..
Also if there new they will keep increasing in loudness starting around 2k miles on them...
Old Jun 29, 2010 | 11:42 PM
gregski's Avatar
gregski
I put the BCT baffles in my V&H Big Shots and absolutely love the sound. Only took about 15 minutes to do.
JDSporty
Aug 31, 2015 08:58 PM
decencyxdefied
Mar 22, 2013 10:48 AM
Kojax
Jul 26, 2010 02:16 PM
mrtac2man
Jul 2, 2010 04:18 PM
Kojax
Jun 7, 2010 06:54 PM
